Old 07-21-2020, 03:10 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default MSD 6425 and 2 step?
I wired in a 2 step on this box. I connect 2 step between grey wire and tach and cant get it to work. Blue wire connected to button on brake pedal Im lost. Help!
Old 07-21-2020, 04:58 PM   #2
Hacksaw
Liked 312 Times in 175 Posts
Default Re: MSD 6425 and 2 step?
You should have 4 wires from the 2 step. Grey tied in to tach and Ign box, Red to 12 v, Black to ground and Blue to switched 12v ( normally open ).
Old 07-21-2020, 05:28 PM   #3
cad
cad's Avatar
Liked 93 Times in 52 Posts
Was it a new 2 step? No red light when activated by 12v on the blue wire?
cad is online now   Reply With Quote
Old 07-21-2020, 05:46 PM   #4
Jeff Stout
That is correct. It still wont activate. 12v from brake button to blue wire when activating.
Old 07-21-2020, 06:13 PM   #5
Hacksaw
???? Did you check with a volt meter that you are energizing it with 12 volts? You maybe losing voltage if your going through a brake light switch. That's all I got.
Old 07-21-2020, 06:46 PM   #6
Jeff Stout
Red light does come on when activating
Old 07-21-2020, 06:48 PM   #7
Jeff Stout
Actually going to check right now for 12 volts at button
Old 07-23-2020, 08:29 AM   #8
Hacksaw
Figure it out?
Old 07-23-2020, 09:09 AM   #9
Jeff Stout
Figure it out?
Check things out again and now it works. Thinking new button is suspicious. So damn hot out here making it tough to work.
