Liked 77 Times in 31 Posts
Is aviation fuel ok to fire up a drag motor.never used it before,I usually get fuel in Buffalo area but border closed ,#%&# china virus
Liked 5 Times in 4 Posts
I would think it would be, back when I started racing in 1989 that's all we used but that's probably because we didn't know any better 😂
Liked 708 Times in 285 Posts
For starting and basic running its ok. Stock car racers love it but it just builds to much heat and bad for lubrication. You can add marvel mystery oil for lubing
Liked 55 Times in 17 Posts
I wouldnt leave it in the fuel system too long. Run it all out or drain it when your done...
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car. |
Liked 38 Times in 14 Posts
Nothing wrong with running 100 LL Avgas. I got friends of mine running it in 15.1 race engines and using a 350 shot for finish line games no problem. The racer that won the Million a few years ago Johnny Bracket Racer runs it in his SR 20 615 and he has lots of racers that run it down their in the deep south. It will last way longer than race gas before it goes bad.
Liked 292 Times in 147 Posts
I put some in my '71 Duster bracket beater last fall as I needed some fuel to move it around at home...left it in all winter with zero issues. Topped off the tank with some fresh Sunoco and the car went 11.55, 11.54, 11.55, 11.56 first time out. Motor is around 11.5-12:1.
Liked 5,150 Times in 1,966 Posts
I used to use it locally in a 9 to 1 400 Pontiac. Couldn't tell the difference from C-12.
Oh yeah, I could...The price! Up until a few years ago, you could pass off Avgas as one of the approved fuels. Once that was discovered , they killed that one in a hurry.
Liked 173 Times in 52 Posts
My brother has an aircraft restoration business. He uses 110LL in every thing that requires high octane gas, his hot rods, boats, golf cart, off road stuff. In 5 gallons he mixes 1/2 cup Lucas fuel injection cleaner/conditioner and 1 cup toluene. I’ve used this formula for years in my street Fairlane as Weber IDF carbs won’t tolerate ethanol. Lasts a long time in the car, no side effects.
I buy it at a local Airport that has a self serve pump. Kelly |
Thank you all,for input ,gona try it,
Liked 320 Times in 102 Posts
A long time ago, while on active duty, we all ran 115/145 Purple AV Gas in everything we drove. The price was right. It was the best smelling fuel that I have ever used. Up on the wing filling tanks, that fuel was so volatile it cast a shadow across the wing...
R-3350 Twin Row Radial Engines - 3350CI = 3850HP
