Liked 244 Times in 26 Posts
Can anyone share the main governing equations for torque converters?
I think Russ Abrahams (sp) had something, but I can't remember them at this time. |
Liked 239 Times in 114 Posts
One of the formulas is K=n/square root T
K is number that is the looseness of the converter n is the stall speed T is the engine torque Russ Abrams 3011 GT/FA |
Liked 99 Times in 60 Posts
some years ago Brandon with BTE did an extensive and informative series about a - z on the subject. Maybe that post is somewhere in the archives.
If it can't be found, maye Brandon would repost the series.
Larry Woodfin 471W |
Russ, thanks for the reply.
Units are rpm and ft*lbs? But there must be something about torque at an rpm. Say you have an electric motor with a flat torque curve of 500 ft*lbs and you want stall of 6,000 rpm. What additional info is needed? |
That is the whole point of that formula . You have to develop a K factor that gives you the rpm you want with the torque you have at that rpm . In general you have different stators and different pumps that will give you a combo that matches the K factor desired . units are in rpm and ft.lbs.
Liked 172 Times in 81 Posts
If you can find a copy, "design of single stage, three element torque converters" by V. J. Jandasek explains torque converter function very well, including K factor. You might be able to get a copy from the SAE or it is in the third edition of "design practices, passenger car automatic transmissions", published by the SAE.
Jim Mantle V/SA 6632 |
Liked 73 Times in 36 Posts
It might seem insignificant to most, but when you try to do math without using the correct units one will get incorrect answers.Torque is a twisting force and is typically expressed in lbs-ft while work is typically expressed in ft-lbs (energy). Yeah I know that seems to be nit picky but it makes a difference when you practice unit cancellation in the mathematics on the subject material.
![]() Regards, HB2 ![]() Dissident |
