Old 08-09-2020, 07:47 AM   #11
richie 2
Liked 205 Times in 93 Posts
Default Re: leaking th400
thankyou everyone for your help! ive have the fluid level to the dipstick full mark, WITH the deep pan on...did not remark the full mark...2 3/4" deep pan.
Old 08-09-2020, 09:49 AM   #12
Mark Ugrich
Liked 71 Times in 38 Posts
Fluid level cold should be at “add 1 pint” ATF will expand as it heats up.
Old 08-09-2020, 10:01 AM   #13
richie 2
1 1/2" ...full mark to dipstick end.
Old 08-09-2020, 10:11 AM   #14
Mark Ugrich
Are you using the oem dipstick and tube or an aftermarket ? Even with a deep pan I believe the fluid level should be below the pan rail. If it’s an aftermarket dipstick try draining the pan so the oil level shows about 1/4 up the dipstick cold. Then go for a test drive heat cycle the trans and recheck to see if the oil level is at full when hot.
Old 08-09-2020, 10:46 AM   #15
richie 2
we originally had a fancy milodon unit. i thought it was the leak source, went back to the factory piece. will get it sorted out and go back to fancy...
Old 08-09-2020, 10:58 AM   #16
Adger Smith
Liked 880 Times in 311 Posts
You just need Flex Seal
Adger Smith (Former SS)
Old 08-10-2020, 01:48 PM   #17
richie 2
pan manufacturer says fill to the factory full mark...WTF... the flex seal idea is sounding better adger...
Old 08-10-2020, 02:34 PM   #18
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Before you start throwing parts at the transmission you really need to locate the source of the leak. My days as a GM tech when I had a complaint of a transmission leak, I cleaned the entire surface areas with brake clean and then used air to make sure it was completely dry. Next I used spray tracing powder and sprayed the entire area., in a short time you should be able to see the powder turning a pinkish color at the source of the leak. It may be as simple as transmission fluid leaking around the front pump cover bolts that would make it look like a pan rail leak.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 08-10-2020, 03:11 PM   #19
Mark Ugrich
I’d say the manufacturer is wrong. In 40 years as a tech, I’ve never started a trans with the level at the full mark.
Old 08-10-2020, 08:35 PM   #20
richie 2
with the pan off, dipstick in, the full mark is higher than the trans/pan surface. the modulator valve bore is right there too....sure seems to be seeping out there. the valve and o/ring fit feels sloppy. measured it all up and installed theres not much crush on the o/ring, .020" roughly...
