Old 08-12-2020, 03:14 PM   #1
Moparteacher
Default How to best modify Smith lifter?
Hola!
I'm moving over to a solid grind. New, milder grind. I would like to continue using my very low mileage Smith Machine low travel "composite-base" hydraulic lifters on this new flat tappet solid grind. The lifters have .015 travel.
Obviously the correct thing to do would be to purchase new lifters, but it's not the preferred option...today.
I prefer to run as is, or modify the Smith Machine lifters. $
So, option #1, Run as is and if so at what lash? (Cam grinder recommends .010" hot.)
Option #2, Shim plunger with .015" stainless shim material and leave check valve assembly in lifter. If so at what lash?
Option #4, no shim, no check valve so lifter does not fill and hold, and run as "take-up" lifter with zero lash (or less) so the face stays in contact with base and lifter compresses and bottoms .015" or so upon ramp-up. And if so, block oil feed hole or leave open?
Or different modification?
What works without banging the composite base into little pieces?
BBM 383
Thanks,
Gary
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
Old 08-12-2020, 03:29 PM   #2
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: How to best modify Smith lifter?
“What works without banging the composite base into little pieces?“
What works?...Tool Steep lifters with an edm hole.
This is a conundrum...a pay me now (very little comparatively speaking), or pay me later (a crap load). Your choice...been there done that.
Bill Grubbs is offline   Reply With Quote
Old 08-12-2020, 04:22 PM   #3
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
I would want to know about what lash ramp that solid lift cam has. If you went to solid lifters, what does the cam grinder want for hot lash?
Stan
Old 08-12-2020, 06:08 PM   #4
MR DERBY CITY
Liked 8,129 Times in 1,535 Posts
Hello, to make a long story short....THROW schubeck/smith lifters in the garbage can AND/OR sell them to someone you don’t like......Like Bill said....TOOL STEEL......He has been there and done that...l.
MR DERBY CITY is online now   Reply With Quote
Old 08-12-2020, 06:26 PM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
Option #2 is the way I would go.
16 grenades with the pins half pulled out...now that's another story.
"That'll never work....."
Old 08-13-2020, 06:38 AM   #6
Liked 10,850 Times in 2,254 Posts
with those lifters the fuse is lit and the bomb will go off, the question is when?
Old 08-15-2020, 12:07 PM   #7
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Just out curiosity why can’t you just take the inside spring,piston and out and just install the pushrod seat and retainer that’s all that a solid lifter has.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 08-15-2020, 12:39 PM   #8
jmantle
Liked 172 Times in 81 Posts
Won't work if you have pushrod oiling, nothing to meter the oil flow.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 08-16-2020, 03:04 AM   #9
Moparteacher
You can. The pushrod seat (no pushrod oiling hole) bottoms on a shelf at .015". Whether or not it'll last...the jury says Boooom! And, there's plenty-o-proof to validate the jury.
Gary Weaver
