Old 08-14-2020, 10:29 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Wire Shielding EMI or RF Noise?
I am still having issues with erratic tach signal at high rpm in the data log and I even see it on the tach as well. My data logs have always been very choppy and jagged which makes the ECU do crazy things and even hits rev limiter which I have set very high.
I shielded my trigger wire that goes from ECU to Crane ignition box. I make sure to keep Magnecor wires away from sensor wires. Some distributor power and trigger wires DO pass by the alternator which makes me wonder if that is an issue. I have checked all grounds, made new grounds, use dielectric grease on plugs and boots, not sure what else to do.
I am told it could just be the nature of a dual-sync distributor that gets its crank signal using the hall effect and harmonics involved but I would like to know which other wires may need shielding.
'65 Mustang SS/L & L/SA
Old 08-14-2020, 01:00 PM   #2
Painter
Liked 162 Times in 45 Posts
Default Re: Wire Shielding EMI or RF Noise?
I think that I would completely eliminate the alternator first. Belt off, wires off and isolated make run and see what it does. Maybe install extra grounds. Start with one from ignition box chassis to known ground. And do t trust any grounds! Us the “tug test” on every connection ground and hot. Steel wool all terminals and where they connect.
Painter is offline   Reply With Quote
Old 08-14-2020, 09:01 PM   #3
SS3860
Liked 170 Times in 56 Posts
Electric fans are a good source for interference also. Separate all ignition wiring from fan wires.
SS3860 is offline   Reply With Quote
Old 08-14-2020, 09:12 PM   #4
Keith 944
Keith 944's Avatar
Try a 10k ohm 1/2 watt resistor in tach wire
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 08-15-2020, 12:03 AM   #5
CMcAllister
Liked 920 Times in 259 Posts
I keep ignition wiring and "dirty" lines (alternator, fans & motors) separated as far apart as possible. And twist or braid the ignition trigger wires.
All grounds are connected to the ground post of the battery with copper - wires, cables. Don't rely on sheet metal.
Would be interesting to see what happens if the alternator is not functioning on a pass.
Old 08-15-2020, 12:12 AM   #6
FED 387
Liked 333 Times in 180 Posts
try grounding the head to the block and the block to the frame or body with the old style braided ground straps--NEVER use solid core wire for ground wire --if you do use braided wire make sure it is of sufficient gauge and not only crimped but put a bit of solder on the wire and connecter crimp area to make sure it is really grounded ---
Old 08-15-2020, 09:04 AM   #7
Painter
Solder is often confused as the very best in connections, when in fact poorly solder connections are very bad. If you don’t know how and have good equipment then stick with good crimps and vigorously apply the “tug test”!
Old 08-15-2020, 03:24 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 885 Times in 238 Posts
Too many devices on a common ground can lead to r/f noise .
As was mentioned the fan is the single dirtiest source on the car followed by the electric fuel pump.
I use ferrite core shields on everything .
I use the type with a plastic case that snaps together around the wire . Very inexpensive, available on Amazon ,EBay .
The old school and still one of the best ways to find the source is to use an old cheap AM pocket radio tuned down to lowest end of the band ,around 540 . it will pick the culpret just about every time.
Old 08-16-2020, 10:17 AM   #9
Bobby Fazio
Tom where do you put them? On the plug wires, signal carrying wires, 12v or ground wires?
Old 08-16-2020, 11:43 AM   #10
Tom Goldman
Bobby, you place them on the supply b+ wire , you can also place them over twisted pairs from the ignition triggers and the coil primary
