Old 08-22-2020, 03:10 PM   #21
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Default Re: Anti- sieze on NGK TR55 plugs
Originally Posted by curtis reed View Post
I use this in aluminum heads.
I wonder if this is made differently from normal Anti Seize products ? I worked in the food manufacturing business. During our maintenance training seminars they explained to us that never seize is loaded with very fine ground up glass. The glass wont rust, that's how it won't seize. We had Food Grade Never Seize, in which the glass is ground up much finer. It doesn't work as well as the standard, but federal regulations mandated food grade ( We made breakfast cereal.) Also, just for information,we had some guys trying to use it as a lubricant, like putting a dab on a new seal instead of a grease or proper lubricant. Its abrasive and should not be used for that purpose.But what I'm wondering about, is how much of an insulator do you think this seize creates? The plug grounds through the threads right? It would have to be giving up some continuity and possibly change the heat range in the process? ...
Jeff Niceswanger 3740 SS
Old 08-22-2020, 05:40 PM   #22
SSDiv6
Jeff,
Yes, its composition is different than Never-Seize. The Champion 2612 is a Graphite based lubricant.
The chemical composition of anti seize lubricants is extensive and it is based on the final use and application. I have never heard about ground up glass, however, many of the anti seize products contain metallics. FDA/food approved anti seize products are chemically inert so they would not react with oxygen, chlorine or water, and do not contain any metallics. They are based on fish and mineral oils.
As long as you use a good high temperature Copper or Nickel based anti seize, that does not contain Moly, the heat range will not be effected and you will still have proper grounding and continuity. Most of the products I recommended have at least 25%+ of Copper or Nickel metallics in its formulation,
