Old 08-23-2020, 08:35 PM   #21
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Default Re: First VS Worst red light
Originally Posted by B Parker View Post
I just got home from the Epping Sports Nationals. I watched several higher HP cars blow the tires away from poor starting line prep. I have raced both fast and slow stockers. I'm all for true start. But if the faster car spins the tires because lack of starting line prep you get a rerun. If you think there is such a big advantage with a faster car than build one. BP
What if just the slower car spins due to bad track prep, rerun as well?
Lane Weber
Old 08-23-2020, 08:53 PM   #22
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
well boys and girls ,,you can flame me if want but i run bias ply slicks and had the choice of getting radials for this race ,, yep radials are faster on a good prepped track ,, in heads up you need to have them to take the best advantage you can but ,,however i ran both lanes this weekend and my car went down with no issues to with others who didn't , yeah i have been on the bad side of track prep with radials ,nhra does there best with the tools at hand ,,if your car is set on kill all of the time chances are you wont go rounds ,,
just my 2 cents ,, been to the movie
gmonde
fuel cars don't get reruns ,, barry dont beat me up or throw burgers at me ,, just my take !
my opinion whos go's red first is out
Old 08-23-2020, 09:35 PM   #23
J DeForrest
J DeForrest's Avatar
Liked 73 Times in 18 Posts
Originally Posted by Lenny5160 View Post
If there is a logical argument against TruSTART, I’d love to hear it.
If you look at it logically, only the tree matters here. Keep out any other fast car vs slow car advantages/disadvantages. I have been running S/SS for only 15 yrs, but been around it for over 40, and have never ran into ANYONE who thinks there is an advantage to the slow end of a staggered tree. The rule is fine as-is, as it can level out the non-clean tree racer in rare instances. This Tru-start in MY opinion is one baby step towards 'everyone gets a trophy'
The only situation Tru start makes sense to me is a delay box class with crosstalk on, but that is another conversation.
superstock5150@gmail.com
J DeForrest is offline   Reply With Quote
Old 08-23-2020, 10:52 PM   #24
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Seems to be a more civil response this time around.
Dave Noll, EF/S ,?/SA 6526
Old 08-23-2020, 11:17 PM   #25
Jeff Stout
Liked 708 Times in 285 Posts
Non clean tree doesn't hold water with me. At brackets races I pretty much spot all cars and have not seen the case in not having a clean tree. The focus is on the tree, then keep car straight as possible , then after in drive I start looking for opponent . If your watching slow car leave and interfere with your focus I can only suggest more bracket races, team races,s/ss combos and at the big div and nats you can hopefully go more rounds.
Old 08-23-2020, 11:28 PM   #26
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
You want rules that are rational,make sense and are not arbitrary.
First is worse is arbitrary. Arbitrary is authoritarian, authoritarian is leftist.
The argument because the fast car doesn't have a clean tree, it should given the advantage of first is worse, isn't a rational argument. It's an opinion.
Ya definitely don't want subjective (opinion) rules.
Objectivity through rational thought is western and masculine concept liberals challenge on a daily basis across this country, and we're losing enough ground as it is.
You want rules that are objective , make sense and are not arbitrary..
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 08-23-2020, 11:34 PM   #27
Jeff Stout
Still wondering why first is worse in a heads up. This is a performance class and fastest car in heads up should be the winner first redlight should not be relevant by some of your way of thinking
Old 08-23-2020, 11:41 PM   #28
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
There is a concentration advantage to be gained for the faster car under TruSTART as well. Without it, I know I'd have a tendency to sneak a peek to the other side to see if my opponent happened to go red. With TruSTART, the slower car's bulb always shows green so there's nothing to see over there. It helps me keep my mind where it should be.
S/ST 51
S/C 53
Old 08-23-2020, 11:55 PM   #29
Mike Rietow
Take a rational approach in looking at it. When does a drag race start? Answer, when two cars start the clocks.
It's arbitrary to declare one contestant loser, before the race even starts.
It takes two to have a drag race.
If you make a single it's not a drag race, it's a pass or a lap..
Old 08-24-2020, 08:24 AM   #30
Mike Pearson
Mike Pearson's Avatar
Liked 1,983 Times in 597 Posts
If it came to a vote I would pick the Tru start. Technology has changed over the years and this could be one of the improvements. I don't remember if it would have ever helped me. I doubt it would com in to play that often.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
