Old 09-12-2020, 08:00 PM   #11
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Broken Front Wheel Studs
Also something to look at is what is piloting the wheel , is it the studs or the id of the rim . Might have a runout problem or the rim moving on the hub when coming down from a wheelstand . I run Strange hubs with screw in 1/2" studs and never have had this problem. Lugs torqued to 65 ftlbs.
Old 09-12-2020, 08:01 PM   #12
jerry witzel
jerry witzel's Avatar
Liked 44 Times in 15 Posts
I torque my lug nuts to 100 ft lbs front and rear and have never had an issue. Those lug nuts look awfully long, are you sure they are not bottoming out on the hub and not tightening correctly on the wheel.
Old 09-12-2020, 08:57 PM   #13
james schaechter
Just for kicks try calibrating your torque wrench or trying one that is known to be accurate.
James Schaechter 3163 STK
Old 09-12-2020, 11:00 PM   #14
Shadylane
Shadylane's Avatar
Liked 173 Times in 52 Posts
Breaks the studs on both sides. Car is not capable of wheelstands...yet.
I looked on Welds website for the torque specs.
I’ll check out what pilots the wheel.
Kelly Lane Stk4991
Shadylane is online now   Reply With Quote
Old 09-12-2020, 11:06 PM   #15
Shadylane
Shadylane's Avatar
Originally Posted by Kirk Morgan View Post
Iam wondering if the inner diameter of the wheel is interfering with the outer diameter of the hub causing a wedge effect.Can you unscrew the broken studs out of the nuts without much effort? If they wont i would think there is some kind of a wedge affect going on..
I had to remove the stud from the lug nut with vise grips. It wasn’t handy until it was half way out. Never thought about hub interference with the wheel.
My torque wrench is within 4 pounds of my friends new Snap On wrench. I guess I could lower the torque number a bunch.
Kelly Lane Stk4991
Old 09-13-2020, 12:17 AM   #16
RJ Sledge
Liked 290 Times in 92 Posts
What’s your BC measurement on the hub and what is it on the wheel.
Early Ford Mustang Fairlane maverick pinto was 4x4.5” and later fairmont models were 4x108mm (around 4x 4.25”).
Make sure you are using the correct BC on wheel and hub.
Studs have fatigue from a register that’s too loose and allowing it to flex.
The pics of your hub stud hole look rough, was it an original Aero Space hub or modified for a different BC?
Not knocking your equipment.....just imo lol.
Good luck
RJ
RJ Sledge is offline   Reply With Quote
Old 09-13-2020, 12:41 AM   #17
CMcAllister
Liked 920 Times in 259 Posts
Plenty of cars out there with Weld wheels and Aerospace brakes, and aren't spitting lug nuts out on the floor. Fit shouldn't be an issue unless parts are made wrong. And unlike axles, front hubs that have the rotors bolted to them don't have a register to center the wheel. Instead they rely on the nuts.
One problem I had with screw in studs in an aluminum hub is the stud backing out of the hub as the nut is torqued. Studs should be torqued into the hub to manufacture's spec (Strange says 65 lb.ft.). I use red lock tight as well. Even doing that they would want to turn. I had to use a socket or tool to hold the head of the stud on the back of the hub while torquing the nut to prevent it.
As has been recommended, I would replace the studs with good USA parts. While talking about length Strange does in fact offer 2 1/2" studs.
Old 09-13-2020, 08:20 AM   #18
Alan Nyhus
Liked 799 Times in 236 Posts
Check the hub fit to the wheel center. In the pic of your hub, the inner edge where it transitions to the flat hub looks pretty shiny...like maybe the wheel isn't coming up flat to the flat of the hub.
"That'll never work....."
Old 09-13-2020, 09:30 AM   #19
pmrphil
Liked 348 Times in 152 Posts
If the broken stud wasn't free in the lug nut that tells me that the stud was stretching, and staying stretched, past it's strength limits. Better quality studs should help.
Phil Molski
PMR Performance
S/C 1623
Old 09-13-2020, 09:37 AM   #20
Liked 10,836 Times in 2,252 Posts
From the picture of the hub and the wheel it looks like it has two different bolt circles. It look like you are using the smallest of the two on the hub. Have you tested the wheel to the larger bolt circle. When we used Aerospace brakes the radius on the back side would not let the shoulder of the bolt seat completely. We had to take a .020” cut to fix and still had to observe radius. Good luck.
