Liked 272 Times in 108 Posts
I ran across a digital voltmeter in a old tool box. I don't remember where it came from. I put the red and black wires across a battery, and it works! Even flashes on and off under 12V. So I think im going to install it in my car.Here's my question. There is also a purple wire on it. What could that be for?
Liked 125 Times in 33 Posts
It’s likely lighting.
It IS lighting. But not backlighting since it is digital. So when there is no power on the purple wire, the display is bright . When power is on the purple wire,the display dims.
My car has no master cut off switch and I normally do not disconnect the battery, the gauge will display forever, so I hope the parasitic draw is tiny. |
Liked 162 Times in 45 Posts
If you have msd ignition, they live a lot longer if you disconnect the battery at night and after you leave the track.
Liked 60 Times in 12 Posts
Everett, the purple is to dim it, if I’m remembering the ones I had before, correctly. I just capped them, with a crimp end.
2894 STK |
Kenny..now I remember where that gauge came from..It was in that center console in the Cutlass!..along with 16 miles of wiring LOL. I found a new home for it.
Liked 99 Times in 60 Posts
the purple wire is an option to dim the display when the lights are on. You can connect the purple wire to a tail light or park light on wire.
Larry Woodfin 471W |
#9 | |
Liked 100 Times in 51 Posts
Dan
Dan Foley SC 4698 |
