Old 09-26-2020, 09:36 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default planning a new stocker
Fellow class racers;
Monte Pannell and I are in the planning stage of building another stocker. We have nothing and are beginning with a clean slate.
The one requirement is carburated. That is our experience and we want to go with our strengths.
In addition, to be practical, it will most likely be a GM body with SBC or BBC power. [again, that is our area of experience]
We would enjoy hearing your feedback in ref to good packages to build.
NOTE: we are experienced craftsmen and receive much of our pleasure from the building. In a perfect world, we could find a nice, clean, "core" body as the beginning.
Larry Woodfin 471W
Old 09-26-2020, 10:16 AM   #2
SDT1DYI
Liked 456 Times in 148 Posts
Default Re: planning a new stocker
Larry, Nice to hear about your new Stocker project.
Second Gen Camaro SBC. 70 & 71. The 71 270 OEM HP is NHRA rated at 274. Dished piston motor, 487 head. Natural H car.
70 350 2 barrel natural N car
NHRA rated 224 HP ( very soft rating), uses 441 head. Uses the big 2 barrel, 1.375 Venturi Much easier to run 1.0 + under with this combo. ( If you want to go for #1 Qualifer).
Good luck with what ever you build
Steve Teeter STK # 620
SDT1DYI is offline   Reply With Quote
Old 09-29-2020, 05:08 PM   #3
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
85-86 Monte Carlo SS. 305 HO (flat top, big cam) factored at 248 for a natural K/SA car, or 249 with a stick. Seems decent to me considering there is so much readily available For the chassis, and the engine combo.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 09-29-2020, 05:23 PM   #4
Liked 10,926 Times in 2,257 Posts
69 Camaro 396 375/405 It should be able to go 1.20 under most every race for awhile.
Old 09-29-2020, 05:45 PM   #5
Billy Nees
Well Larry, if that's the case then why don't you try something different?
Billy Nees 1188 STK, SS
Old 09-29-2020, 07:04 PM   #6
Dragsinger
Billy, I am all about different. Got any suggestions?
Larry Woodfin 471W
Old 09-30-2020, 09:07 AM   #7
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Without checking the Class Guide but while still following your wants list. Early C10 truck, wagon or an El Camino would be different. Any 4 door GM cars that had a cop/ pursuit motor in them from the factory you could make into a screamer? I am all for different, but with parts support too.
Andy Friar
Andy Friar is offline   Reply With Quote
Old 09-30-2020, 09:57 AM   #8
e vassar
Liked 272 Times in 108 Posts
Agreed! El Caminos are way cool,and the best thing about them are the trailing arm/coil spring rear suspension. Pretty easy and inexpensive to make them hook with 9" tire. And loosened up the front suspension has a lot of travel.
Old 09-30-2020, 02:19 PM   #9
Dragsinger
an El Camino is a good idea and would be a cool buildup.
Larry Woodfin 471W
Old 09-30-2020, 05:02 PM   #10
Jim Hanig
Liked 99 Times in 49 Posts
If you got a 30000.00 engine
