Old 10-01-2020, 10:04 AM   #11
nhramnl
Liked 358 Times in 83 Posts
Default Re: 350/360/330 SBC with E-brock heads - CRICKETS
Does anybody REALLY think that in these COVID times, there will ever be teardowns, as we all knew them? Hell, there isn't even tech inspection anymore. You write what you want your car to be on your tech card, and your wish is granted. I'm waiting for the first guy to show up with a big-block, claiming it's a 283.
Old 10-01-2020, 10:15 AM   #12
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
The 170 cc intake could be reduced enough for most small block stockers..
the 185 not so much
Old 10-01-2020, 11:03 AM   #13
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Can I get the number for the 170 heads. My heads are 168cc. Thanks
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 10-01-2020, 11:14 AM   #14
james schaechter
Liked 1,443 Times in 302 Posts
They checked valve lift this year at one race. Throttle bodies. Not a piston pull, but some looks
James Schaechter 3163 STK
Old 10-01-2020, 11:24 AM   #15
Alan Nyhus
Liked 800 Times in 237 Posts
Originally Posted by Mike Taylor 3601 View Post
The 170 cc intake could be reduced enough for most small block stockers..the 185 not so much
Mike, NHRA shows the Edelbrock heads as having 172 c.c. int. port volume and accordingly adds 5 h.p. to the factor if you use them.
However, as supplied by Edelbrock, they are 185 cc intake ports.
"That'll never work....."
Old 10-01-2020, 11:32 AM   #16
Daran Summerton
172 is for SS. Stock is same as factory.
72 cutlass
Old 10-01-2020, 12:38 PM   #17
Bobby Lundholm
Liked 128 Times in 50 Posts
Dart is the same way. I ordered a set and they were 180cc. I called Dart and talked to their quality control and was told that the tooling has been worn making the runners larger than advertised. I do know if you find an original older set they do match up to NHRA's specs.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 10-02-2020, 02:59 PM   #18
Mike Taylor 3601
That's not good...
