Old 10-11-2020, 10:45 PM   #11
djm670
djm670's Avatar
Liked 186 Times in 48 Posts
Default Re: Front tire pressure/Reaction time
We used to have three sets of front tires and wheels, three different size and would run the size that gave the right reaction times at a particular track. Never played the fron tire pressure game.
djm670 is offline   Reply With Quote
Old 10-13-2020, 04:04 PM   #12
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
I am thankful for all the info and
insight on things to try.
There nothing like the racing community
helping out a competitor
Where else would you find this
Thank You
Willyracer is offline   Reply With Quote
Old 10-13-2020, 04:50 PM   #13
Hacksaw
Liked 311 Times in 175 Posts
Originally Posted by Stewart Way View Post
Hacksaw. Think the rule is the opposite. +-3/4 with max variation 1" side to side.
You Sir, are 100% correct.
Old 10-13-2020, 05:04 PM   #14
Ed Wright
Ed Wright's Avatar
Tech guy told me one inch side-to-side. I use 3/4 inch. Been checked a couple of times.
And pressure effected my foot brake cars more than the trans brake car. Testing would be required to determine how much, IMHO.
Ed Wright 4156 SS/JA
Old 10-13-2020, 07:09 PM   #15
GTX JOHN
The tire height makes a significant difference in reaction time.
5 or 10 Lbs pressure in the tire = very little that I can find.
Maybe if I took the front runners from 40 to 10 it might make a observable
difference. Someone can tell me = I am not going to try it!
My Blood Sugar level makes a lot more difference = Of Course - I am old!
John Irving
741 Stock
741 Super Stock
Old 10-13-2020, 07:26 PM   #16
Jim Caughlin
Liked 805 Times in 245 Posts
I'm not sure of the exact height of the stage beam but as an experiment, I put a 3" tall block in front and behind my 26" tall tire, the measurement at 40 PSI and 10 PSI was exactly the same. Based on that, I think the change in reaction time is a mental thing and not real.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 10-15-2020, 11:49 AM   #17
LittleBubba1150
Liked 4 Times in 2 Posts
Many different opinions from many great drivers but in my personal opinion I don’t feel front tire pressure is very important. I normally don’t check front tires after I leave the house unless one or both look like they’re leaking for some reason. And pretty similar with rear tires. I’ll usually check them every morning as they can vary quite a bit with outside temperature. And sometimes I’ll give them a check to make sure they’re about the same throughout the day. But whatever works for you or makes you feel most confident and comfortable is what’s most important!
LittleBubba1150 is offline   Reply With Quote
Old 10-15-2020, 01:27 PM   #18
GTX JOHN
We check all four each morning and the rear
most times in the staging lane unless we are
rushed.
John Irving
741 Stock
741 Super Stock
Old 10-15-2020, 04:23 PM   #19
jamie2370
Liked 239 Times in 90 Posts
[QUOTE=GTX JOHN
My Blood Sugar level makes a lot more difference = Of Course - I am old![/QUOTE]
From a fellow diabetic..... yes it does. I keep good check on mine because it makes a HUGE difference in react and driving the stripe.
I check my tires in the morning and thats about it lol. 38frt & 19rear is my bracket tune
Rpms will change react the most, mine is 200 for .010 up to a certain point
jamie2370 is offline   Reply With Quote
Old 10-15-2020, 08:41 PM   #20
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I feel the same way. I typically check mine before the first and second passes of the day, and that's about it.
With the dragster I pay a little more attention and check before each pass, but I buy the cheapest gauge that is in the range needed.
S/ST 51
S/C 53
