Old 10-29-2020, 09:23 PM   #1
Stewart Way
Liked 70 Times in 22 Posts
Default Motorwheel flies on 5/8 studs
Has anyone put a set of flies on 5/8 studs? if so, how did you do it. Don't have the wheels at the shop but measurement I have for lug hole is .762. The unthreaded portion of the stud is around .68. Thought about cutting he shank off the lugs and boring to fit the stud but hate to ruin the lugs. Or have bushings made to fit stud? Any other ideas.
Stewart Way 2424 SS
Old 10-29-2020, 09:47 PM   #2
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: Motorwheel flies on 5/8 studs
When I used Motor Wheel Flys I had machine shop make a set of spacers, used flat washers and nuts. No problems, just check the torque occasionally.
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 10-30-2020, 12:03 AM   #3
Stewart Way
That seems to be the best Idea. I just thought I would check to see if I was missing an available solution I didn't know about.
Stewart Way 2424 SS
Old 11-02-2020, 12:05 PM   #4
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Hello Stewart;
I have done this as I run the "Fly's" on my car.
These are the three ways I did it starting from easiest/cheapest to hardest/expensive.
1) Go to a hobby store and pick up a 3' piece of brass tubing that is .750 O.D. and .6875 I.D. Cut it to desired length. The part number I have for it is K+S9225. Really easy and works great. $20.00.
2) Get some stainless,same O.D. .625 I.D. Machine it to .6875. Cut to length. This was painful.
3) Have the wheels bushed at a machine shop to fit the M/W studs. I did this with a set that the holes were no longer round. Works well but it cost me $300.00.
Allan
55 Chevy is offline   Reply With Quote
Old 11-02-2020, 04:58 PM   #5
Stewart Way
I have access to a lathe so I guess I will make some spacers. Just didn't want to miss out if someone had a solution that was just a slip/press on. Thanks
Stewart Way 2424 SS
Old 11-02-2020, 07:53 PM   #6
NHRA3106
Liked 147 Times in 38 Posts
If you have access to a lathe, the easiest thing to prob do is to take the 5/8 aluminum wheel spacers and neck down to fit hole, and step back just shy of the thickness of the wheel. Double as a locator/spacer...just my thoughts.
Kevin
NHRA3106 is offline   Reply With Quote
Old 11-04-2020, 09:52 PM   #7
Stewart Way
I do have extra spacers so that sound like a a good idea.
Stewart Way 2424 SS
