Old 11-01-2020, 11:03 AM   #111
SSDiv6
Default Re: "Old School" Stocker Cams
Originally Posted by Bunkster View Post
Ford 292 lifter:
Mushroom lifters were used in the early days of NASCAR, allowing camshaft profiles with more aggressive lobes. Direct Connection used to sell mushroom lifters for Mopar applications and also the required tool to modify the block.
Many years ago I heard the story of a racer that was running mushroom lifters in 15 lifter bores and left one bore with a normal size lifter in the event he was asked to pull a lifter to show tech.
Old 11-01-2020, 11:42 AM   #112
Greg Reimer 7376
Liked 719 Times in 220 Posts
Seemed to me that an old GM Performance Parts catalog used to show a mushroom cam and lifter for a small block. Also, doesn't the tech guy sometimes tell you which lifter to pull at random?
Old 11-01-2020, 01:49 PM   #113
SSDiv6
Probably expected the Tech Inspector to say, "Just pull or hand me any lifter"
Old 11-07-2020, 02:08 AM   #114
djm670
djm670's Avatar
Liked 186 Times in 48 Posts
I still have mine too. And his Deck Checker, uses a dial indicator.
Me too, still have both; have used them when dialing port timing on two cycle Ski-Doo snowmobiles in my later years. No more hernia's from carrying heavy blocks and heads.
I believe Harry Doolittle had at least one of every checking tool Red made.
djm670 is offline   Reply With Quote
