Old 11-18-2020, 12:47 PM   #1
HawkBrosMav
Liked 302 Times in 73 Posts
Default SBF Balance question.. Neautral... 28.. 50..
Has any one done any type of testing to figure out the performance changes in a SBF that has been neutral balanced vs the stock 28 or 50 oz balance.. is it worth enough to spend the money on the Mallory or is it so minimal that it'd only be worth trying if you wanted to be #1 at Indy...
Brad
Old 11-18-2020, 12:52 PM   #2
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Default Re: SBF Balance question.. Neautral... 28.. 50..
Brad
0 balance all day...I've ran 0 and 50oz...
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 11-18-2020, 12:58 PM   #3
Maverick
Liked 36 Times in 26 Posts
I believe the newer cranks like eagle are manufactured for 0 balance, so they don't require mallory. Last two cranks I had done required lightening, no mallory
Old 11-18-2020, 01:39 PM   #4
HawkBrosMav
Is this from a performance improvement stand point or just bearing life and overall dependability of the engine's life? Is it actually worth HP?
Old 11-18-2020, 02:09 PM   #5
[QUOTE=HawkBrosMav;628249]Is this from a performance improvement stand point or just bearing life and overall dependability of the engine's life? Is it actually worth HP?[/QUOTE
Dependability and reliability ....cracked blocks are not good
Old 11-18-2020, 02:13 PM   #6
you can get the eagle and scat in 0 or 28
Old 11-18-2020, 02:23 PM   #7
HawkBrosMav
[QUOTE=Stephen & Horace Johnson;628251]
Fortunately in the combo we are running it's never seeing over 6500 RPM we've had a stock crank 50oz motor together for going on 10 years now and have never had any issues outside of now having 1000+ passes on it we finally wore the bearing out.. Don't really need to spend to money/effort on neutral balance if there isn't any performance gain, but wanted to consider the option of if verse the cost buying the Eagle crank and going neutral. if we were having reliability issues I could justify the expense for it, but at this point the investment is simple for potential HP gains for a car that will never make the top half of the sheet on the current budget.
Additional info; were making 300-350 HP tops... not a speed demon by any means haha
Brad
Old 11-18-2020, 05:17 PM   #8
Maverick
I had a few Boss 302 cranks I ran for years, and then I broke a crank, caught it in time. But the metallurgy has changed, So I ran this Boss 302 crank for a long time came to rebuild with rods and pistons, and I opted for a new crank. The cranks wear out. I felt better with a new crank that was made for neutral balance, that one that had seen service since it was made
Old 11-18-2020, 08:29 PM   #9
SSDiv6
Go neutral balance and get the crankshaft from Molnar Technologies. Every time I use Eagle or Scat, it requires work to correct issues.
Old 11-19-2020, 02:29 AM   #10
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
I've got a 28oz cast crank 351c that goes to 7300. It's been together 7 years and didn't get twisted that high till I figured some things out. I had a local machine shop balance it and it feels smooth @ rpm. The external balance gives a tiche less iron flying around Inside the crankcase.
I've also got a recently acquired Molnar massaged crank for my good engine. That's going to be a while though, too many projects.
Dave Noll, EF/S ,?/SA 6526
