#11 | |
Liked 14 Times in 6 Posts
#12 | |
#13 |
Liked 706 Times in 283 Posts
#14 |
Liked 1,034 Times in 368 Posts
MSD's pull ,and need, about 8 amps at WOT . They also get a lot of vibration in our cars.. Put a new high current kill switch in it. Their relatively cheap.
Jeff Niceswanger 3740 SS |
#15 |
Liked 104 Times in 7 Posts
Ck your grounds.
#16 |
Liked 1,842 Times in 429 Posts
Joey this may sound strange
Years ago Micheal Iacono built the yellow SS camaro car was brand new front to back . Then it developed a gremlin changed everything msd fuel pump retire Lee Zane was driving the car. Finally made few runs shutting accessories Bad electric water pump. Wouldn’t do it unless under a load Worth a look
james perrone 1290 STK |
#17 | |
#18 |
#19 |
Liked 53 Times in 24 Posts
[QUOTE=Jeff Stout;629310]Not to bash, but it was a Barry Grant pump. It was aerating the fuel. So the gauge was actually air/ liquid pressure. No O2 sensor at the time. Also at the time I was not to smart and threw about 1500.00 and 7al, wires, new tach, plugs. Checked valve springs twice. Cam timing, compression test. Three different outings at track. It was a real learning experience.[/QUOTE
Jeff This car use to be fuel injected and it still has the high pressure pump in it with regulator to knock down the pressure. regulator is set at 7.5 lbs also we dyno'd the engine and it still has the same power from when it was built |
#20 |
Liked 135 Times in 74 Posts
grounds. disconnect, add serated washers and no lock nuts. nylon in locknut can melt from cranking engine when wire gets hot.
fuel lines. any rubber can actually close down and limit flow when hot |
