Liked 780 Times in 194 Posts
I am researching to see what information really needs to be displayed. With the weight rule as it currently is written, it is hard to judge what would be a minimum and maximum weight race car combination to display.
Would 500lbs. up and down be enough? Looking for feedback and opinions. Thanks.
Liked 328 Times in 80 Posts
Dwight,
As you know, I have the Caprice in SS/PA and will be able to run in GT now. My old ship weight is 3925. I have been running at 3570 on a 3515 minimum. I can easily get the car down to 3300 with me in it. There has been no gutting of the car, all the power windows and seats still in there. I think in this case you would be looking at 700 lbs. With that being said, I don't think I could get it down to the 14 lbs. minimum. I think I can get my 91 Corvette up GT/H at 2780 whereas SS/I I'm at 2870. I realize that it would not be a good move but would make my index go from 10.55 to 10.35 if I wanted to slow it down. The ship weight is 3193, so about 413 lbs. in this case. thanks for all you do for this racing community!! Ernie Neal SS/PA, SS/I, GT/G 354 |
Liked 3,199 Times in 977 Posts
Wow, I was thinking +/- 500 was more than adequate but Ernie proved me wrong. In any case, I don’t think I can get below shipping weight by more than 300 but appreciate all you do!
Liked 51 Times in 12 Posts
I would think with this change the minimum weight would be the SSGT min. However in reality you could not get there with all cars. If I were to pick a number for legal weight reduction I would probably target 750 pounds out as a stretch target.
This change in my opinion has removed the added complexity of GT and turned GT into if you can think it you can build it. I also think with the FWD conversion cars that Front clip / Suspension mods be opened up for all GT Cars or clearly defined most FWD cars have the aero advantage lets not enhance that unless it is the intent. But hey what do I know I'm a Pontiac racer Hmmmm Solstice with a RA 400.... Happy Holidays |
Liked 7,789 Times in 1,744 Posts
Would this matter?
I'm looking at a 2015 rulebook OBTW. In General Regulations under 4:2 Ballast, at the bottom of the paragraph,"Maximum amount of removable and/or permanent ballast, unless otherwise stated under Class Requirements, is 500 pounds. Cars running 8.49 and quicker are limited to 250 pounds maximum, per SFI chassis specification.".
Liked 319 Times in 68 Posts
Easy to add weight to any car legally,start by putting everything back in you ripped out trying to lighten it. When I had my Mustang fox body had to carry over 500 lbs. of ballast to run H/FIA. Did it and was never questioned about anything being illegal.
Lee Valentine 1661 STK |
Liked 693 Times in 205 Posts
With the newer model cars (2000 and up) weighing so much and the ability to remove so much emission and safety equipment out, it is common to being able to lighten the car 700 pounds or more without going to drastic measures. This should be taken into consideration.
#9 | |
#10 | |
Liked 564 Times in 66 Posts
