Liked 205 Times in 93 Posts
hope you's dont mind me in this section. very healthy 496ci/auto, 67 chevelle. holley hp 950 carb. need to determine lean/rich conditions with 8'' of vacume @ idle. egt probes/system in the headers? tks a bunch for any suggestions.
Liked 974 Times in 310 Posts
Put an O2 sensor and data logger in it.
tks glen, who makes that system?
Liked 3,230 Times in 982 Posts
Liked 43 Times in 29 Posts
Here is another option for an monitoring air /fuel ratio:
http://www.daytona-sensors.com/wego-...-displays.html easy to install and has many options
Mark Ruset 2048 STK |
Liked 240 Times in 112 Posts
Ive used an Autometer wideband gauge and O2 sensor in my truck to get a tune out of it. Works great.
Dave Noll, EF/S ,?/SA 6526 |
Liked 27 Times in 19 Posts
With an idle with 8" vac. it must be fairly lumpy, so the wide band won't be very accurate at idle but will be useful above that,
@ idle is the issue. way rich. have been all through the tuning to no avail.
Liked 16 Times in 11 Posts
What have you tried?
Liked 498 Times in 244 Posts
Does that carb have the holes in the butterflies?
On Dominators I've had success with restricting the idle feed holes. |
