Old 12-17-2020, 09:35 AM   #11
MIKE3554
Default Re: ATF any real world experiences with Loosing up a convert
Amsoil super shift has a kinematic viscosity of 100 degrees c of 7.1 and 41.9 at 40 c. If you need anymore info you can check amsoil.com or contact me.
Mike warren 3554 v/sa
MIKE3554 is offline   Reply With Quote
Old 12-17-2020, 11:37 AM   #12
Dave Gantz
Liked 251 Times in 125 Posts
Originally Posted by Glenn Briglio View Post
That's exactly how it's done!!!!!!!!
Bob, kudos, for sure! But I got tired just reading it!
Protecting a soft horse power factor, running an unpopulated class, and drinking beer is another way. lol. Mike Smith taught me that. (RIP)
We didn’t go real fast, but we had a good time and won a few rounds. 11.60’s on (at the time), an 11.85 index. At the time, 25 years ago, D/SA was that class in Div 1. Mr. Horensky kicked our butts, and we did pretty well staying away from Nick Reiter. I don’t remember any others. (I’m sure there were a few.) We also had other engine combos planned, but we never got to try them out.
Pardon the hijack.
Old 12-17-2020, 02:10 PM   #13
Race Clean
Liked 129 Times in 53 Posts
Torco ATF
Viscosity @ 100°C
ATF LoVis 5.9-6.2
ATF HiVis 6.8-7.2
Stop global whining
Race Clean is offline   Reply With Quote
Old 12-18-2020, 10:13 AM   #14
Rsmith38
Liked 28 Times in 15 Posts
Eric Tried the ATI 8 wt Didn't se any difference but I was messing with different converters at the time. still have in the Jeep trans.
1051 Stk
Rsmith38 is offline   Reply With Quote
Old 12-18-2020, 02:19 PM   #15
jmantle
Liked 172 Times in 81 Posts
Hi Eric, I'm currently running Dex VI in the Pacer, have tried Dex 3 and the high viscosity Allison TES295 fluid in the past. Never saw a noticeable difference in stall speed between the 3. PM me if you like, I'll fill you in with whatever I can.
Jim Mantle V/SA 6632
Originally Posted by Eric Merryfield View Post
Test Pig:
The mighty Gremllin, currently running Amalie Type F, which per their spec sheet says is 10-20 weight.
Per the chasis dyno wants 500 looser on the RPM, which is obviously a ton, and not going to happen with just fluid, but with a low HP beast like the Gremlin, we might see more of an effect of the fluid than say your standard 635 HP 396 stocker.......
Reflashing this convertor, too risky. Have a known good enough thing here.
I know just about all the info on the site is about using thicker fluid to lower stall, I'm looking to increase stall as much as possible.
I believe specific gravity is likely the ultimate factor in stall,
So for my type F, using the formula, 141.5/API of 31.5 plus 131.5=.8498
a thinner fluid like their Dexron VI syntethetic with a API of 35 would be a .8681 SG
This is 1.0215% thinner than the type F.
The ATI 0w-8 weight might be a option, I know there are other synthetic fluids out there with real thin weights.
Eric
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
