Liked 2 Times in 1 Post
I'm interested in people's feedback on how they've set up their leaf spring suspension when using CalTracs, Assassin Bars, etc. w/ respect to promoting vs restricting chassis separation.
My original understanding was using these "devices" allowed for more control of the rear suspension on launch w/o having to rely on a large amount of chassis separation as was expected (required?) w/ Super Stock springs, Try-City Launchers, "slapper" bars. However, I'm seeing plenty of Stockers w/ CalTracs & Assasins where there still appears to be significant amount of separation happening. I'm wondering if it's an "it depends..." thing, whether certain chassis combinations (like my Mopar E-body) respond better to this approach, or what other factors may need to be taken into account (leaf spring lengths before & after axle? weight distribution? ...?). For reference, here is the data from a series of passes made before I pulled apart the car (quite a ways back, unfortunately). The CalTracs & split mono-leaf springs were strapped down a good bit w/ the old Ranchos on setting 4 of 5, so there was minimal separation. The front suspension was very loose (possibly too loose) w/ 5-1/4" extension from static ride height. Unfortunately, no good pics or videos to go w/ the data. Also, in case the 60-fts look "slow", it's cuz this is a street/strip car w/ only a 4500-flash converter, 4.10s, and 9" DOT drag radials. Welcome to my build of compromises... - 60 - / 660 / MPH / 1320 / MPH / Weather conditions 1.459 / 6.682 / 101.66 / 10.566 / 126.01 / < No weather #s > 1.468 / 6.677 / 101.87 / 10.561 / 126.00 / 74*, 48%, 30.57" 1.463 / 6.698 / 101.45 / 10.582 / 126.18 / 65*, 42%, 30.38" 1.464 / 6.682 / 101.71 / 10.563 / 126.12 / 72*, 33%, 30.35" 1.459 / 6.681 / 101.47 / 10.570 / 125.97 / 73*, 33*, 30.33" Not asking for "trade secrets", but some feedback would be appreciated. Thx! Last edited by Brad Hawk; 12-18-2020 at 01:49 PM. Reason: typos |
I run Ranchos with Caltracs on same settings
Not a bunch of separation but 1.3s in 60fts. on our 340 Stockers. Very Consistent and well pleased with John Calvert's stuff!!!
Liked 734 Times in 385 Posts
I have not raced in a while. But it used to be that as I improved my 60 foot time my 1/4 et improved. It seems as your 60 foot times get worse you et gets better.
Stan - 60 - / 660 /// MPH /// 1320 //// MPH /// Weather conditions 1.459 / 6.682 / 101.66 / 10.566 / 126.01 / < No weather #s > 1.459 / 6.681 / 101.47 / 10.570 / 125.97 / 73*, 33*, 30.33" 1.463 / 6.698 / 101.45 / 10.582 / 126.18 / 65*, 42%, 30.38" 1.464 / 6.682 / 101.71 / 10.563 / 126.12 / 72*, 33%, 30.35" 1.468 / 6.677 / 101.87 / 10.561 / 126.00 / 74*, 48%, 30.57" |
Liked 232 Times in 69 Posts
You will need a good pair of rear shocks too control the separation. I use Afco double adjustable shocks on the rear of my 67 Camaro which has Caltrac's bars and split mono leaf springs. I tried Competition Engineering 3 way adjustable shocks and QA1 double adjustable shocks. Neither one of these shocks are strong enough to slow down the body separation when using the Caltrac bars. My car 60ft 1.35-1.37 When I brought my car to Mark Markow for some suspension work, he is the one that recommended the Afco shocks. I had just bought a brand new pair of QA1's right before I brought the car to him. Even though they were brand new, he told me they wouldn't be strong enough to handle the pressure from the Caltrac bars. Car hooks hard now.
Liked 431 Times in 224 Posts
I always assumed separation was somewhat the point of the CalTracs. They convert the rotational force of the rear housing trying to "wrap" into a downward force on the front of the spring, causing it to arch and lift the body.
S/ST 51 S/C 53 |
Liked 2,750 Times in 971 Posts
Ask Pete Lanciers.
Liked 140 Times in 51 Posts
I remember seeing lots of very fast stockers that used the Caltracs and the Rancho adj rear shocks. Way back when Top Stock was around this was the recipe.
The more people I meet the more I like my dog Kevin |
Prior to CalTracs, many were using Greg Luneack's Super Launcher Springs. They had lots of separation during launch.
Liked 805 Times in 341 Posts
It was a long time ago but when I first got my CalTracs I sent them a photo of my car and asked them if there was too much separation. They said there was and sent me another set of springs at no charge.
Liked 224 Times in 87 Posts
I run cal trac springs & his 9 way shocks on the back ( set on like 7 } , some of same combos in stock separate more & some less than my car . Looking at some pics of the races from this year alone . I might try to tighten up my rear shocks . And after 10 years of racing & trailing they may be done .
