Old 12-21-2020, 06:49 AM   #11
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Default Re: street/strip engine question
Another option...
https://www.aemelectronics.com/produ...ntroller-gauge
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-27-2020, 05:34 PM   #12
richie 2
Liked 205 Times in 93 Posts
Originally Posted by 1uke View Post
What have you tried?
oh man have tried a bunch...5.5lbs. pressure, holes in butterflies, leaned idle air bleads a couple, jetting is in reason. floats just below sight plug. maybe could lower? plugs r cleaner after a non stop tour...
Old 12-27-2020, 05:41 PM   #13
Bob F
Liked 16 Times in 11 Posts
Idle fuel bleeds are too large.
Bob F is online now   Reply With Quote
Old 12-27-2020, 08:30 PM   #14
pmrphil
Liked 348 Times in 152 Posts
Yes, idle feed restrictions could be a bit large. Did you plug the secondary P.V. and go up 5 or 6 numbers? How much base timing, and total?
Phil Molski
PMR Performance
S/C 1623
Old 12-27-2020, 09:34 PM   #15
slick5861
Liked 2 Times in 2 Posts
Do you have a power valve in the carb or is it blocked off ?
slick5861 is online now   Reply With Quote
Old 12-27-2020, 09:49 PM   #16
richie 2
950 holley HP. nice carb..... 3.5 pv, timing @ 18 inital/35 total. (pump gas)
Old 12-27-2020, 09:57 PM   #17
slick5861
You said 8 inches of vacuum at idle. Was the car in drive or in park when checked ? I always adjust the carb, idle mixture vacuum etc. in drive. Being in park raises the rpm and vacuum readings. Just checking because if overlooked it will not be an optimized setting of the carb. Good luck.
Old 12-28-2020, 09:29 AM   #18
richie 2
idle fuel bleeds? theres idle air jets that ive gone up #75 tp 78...yes slick5681 did vacume check proceedures in drive...
Old 12-28-2020, 10:11 AM   #19
richie 2
found them...checking sizes
Old 12-28-2020, 01:44 PM   #20
richie 2
thankyou everyone for all you help. best i can measure today is .090'' on the idle feed restrictor....this restrictor i was unaware of, therefore its factory size and untouched.
