Old 01-06-2021, 06:00 PM   #451
lynn engels
Liked 152 Times in 26 Posts
Smile Re: OLD Modified Corvettes
mr cates, your not my enemy, im sure if i met you we,d be friends and enough bantering about whats what, lets just see more pics of old corvette drag cars. have a good day sir.
lynn engels is offline   Reply With Quote
Old 01-06-2021, 07:38 PM   #452
JRyan
Liked 112 Times in 31 Posts
Default Re: OLD Modified Corvettes
Lynn. I just want to drive the gold car.LOL! Definitely one of the coolest super stockers out there.
Rick
Old 01-06-2021, 08:07 PM   #453
lynn engels
thats what that car needs is a good driver like yourself
Old 01-07-2021, 08:25 AM   #454
Terry Drinkwater
Liked 26 Times in 11 Posts
There were several beautiful Corvettes that raced out of Montgomery, AL back in the 70's and 80's. One was a candy apple red '62 owned and driven by Bill Bethea. Another was a black '63 (IIRC), owned and driven by Al Capatel. These were IHRA cars, so they prob weren't seen much outside of the Southeast. Surely someone has some pics of those.
I'm told that Bill still owns his car, not sure about Al. Bill's business partner, Kenneth Dickey also had a 'Vette. I believe his was also a '62, which ran in S/S.
Another was the McCann, Cowles and Kamakowski car, driven by Stanley Kamakowski, which was white and was a '67 or '66. (IIRC)
These cars were all Modifieds except for Kenneth's and all were immaculate and always well-prepared.
Anyone remember those cars?
Last edited by Terry Drinkwater; 01-07-2021 at 08:29 AM. Reason: Clarification of names
Terry Drinkwater is offline   Reply With Quote
Old 01-07-2021, 01:42 PM   #455
jimmyparker
Liked 309 Times in 88 Posts
Terry,
I remember these racers and their cars well. They were good racers who ran at Phenix City and Montgomery quite a bit, I always admired their Corvettes and not surprised that Bill still has his.
Jimmy Parker
jimmyparker is offline   Reply With Quote
Old 01-09-2021, 06:15 PM   #456
chopperloco
chopperloco's Avatar
Liked 83 Times in 24 Posts
Originally Posted by dedracer View Post
Schnelker & Losher G/gas Corvette from Fort Wayne Indiana, probably the best time capsule I've ever come across, was parked around 1973. Still retains the 287 & Doug Nash trans it was last raced with.
Doug,would it be possible to see interior and underhood?
Dom
chopperloco is offline   Reply With Quote
Old 01-11-2021, 10:04 AM   #457
Cbrinson47
Liked 56 Times in 33 Posts
Originally Posted by Dyno View Post
It was WAY to HOT at Indy this year to watch any S/SS except early in the morning. Dyno
Beats watching the pro Fuel trash !
Cbrinson47 is offline   Reply With Quote
Old 05-04-2021, 02:17 PM   #458
vette1
Liked 5 Times in 5 Posts
Stick shift nationals. Farmington Dragway June 19
vette1 is offline   Reply With Quote
Old 01-07-2022, 08:31 PM   #459
Doug Walker
Doug Walker's Avatar
Liked 3,290 Times in 300 Posts
Recently owned by Angelo DeCarlo until a few years ago. Was sold to somebody that did a restoration of the Ault & James H/Gas Corvette.
Shown here in the courtyard west of the left lane bleachers at the US Nationals last September.
ID:	61664   Click image for larger version
Old 01-07-2022, 11:36 PM   #460
Bruce Fulper
Liked 54 Times in 33 Posts
Originally Posted by randy wilson View Post
Ok, Here goes. CLASS: ECONO MOD
81 and older cars. No front wheel drive conversions.
9 lbs. per C.I.D.
Min. wt. 3,000 lbs.
Max. 1 750 cfm carb. Choke horn must remain. Baseplate standard 750.
Ford, Mopar, and GM only. Brodix spec head. Only mods allowed angle milling, and polishing combustion chamber. 11\32 valve min. 2.08 max. Titanium allowed.
Cast intake generally available. No external mods. Max 2" spacer.
Any piston, any rod, any crank, any ring package, any bore, any stroke.
No vac pumps, external oil pumps, belt drives, or internal billet pumps allowed.
No computers allowed.
No titanium, or carbon fiber driveline parts allowed, except carbon fiber drive shaft for safety reasons.
Max. 1 clutch disc, no smaller then 10.5 inch. No counter wts. allowed.
Max. primary tube size on header 2". No more then 2 steps on header.
Motor plates allowed.
Cool can allowed.
SpecC-12 VP fuel
Cam lift .750 max at the valve.
Stud mount rockers only, except Mopar.
14.32 max tire size.
Wheelie wheels permitted.
Max
RPM chip allowed. No other chips allowed.
Play back tach allowed.
Maximum 5 forward gears. CLUTCH MUST BE USED IN ALL 5 GEARS IN THE TRUE CONVENTIONAL MANNER.
Removable tunnel allowed.
No more then 50\50 wt transfer.
.4 pro tree only.
Cam must be in stock location, remain stock diameter for engine used.
Lifters must be stock diameter. Roller cams, and lifters allowed.
Any radiator in stock location.
Engine in stock location, plus, or minus 1"
Distributor must remain in stock location.
Crank trigger allowed.
Any head under suspicion must be sent to Brodix, and $500 fee put up for the expense of protested.
After market balancers required. Min, 8 pt cage. (up to NHRA)
1" site plug required in oil pan to inspect pump.
.Autos remove 100 lbs. Must still maintain min wt.
What? No Pontiacs? I have a 326 that will pop your eyeballs out. Would I get to use Edlebrock heads? Or a factory head? I prefer the factory head.
Bruce Fulper is offline   Reply With Quote
