Old 01-08-2021, 09:46 AM   #11
Nmbr1GMfan
Default Re: Accusump/accumulator questions!
Originally Posted by curtis reed View Post
They changed the design a little but that is what I have been using for years with mine.
Thanks Curtis.
Todd Greene
Old 01-08-2021, 08:44 PM   #12
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
I use the Canton Racing Sandwich adapter $92 on Summit, cheaper on eBay...
https://www.summitracing.com/parts/c...BoCG44QAvD_BwE
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
Old 01-09-2021, 08:58 AM   #13
SST159
Liked 20 Times in 16 Posts
Just curious as to why you would not plumb right from the threaded port above the filter as shown in the picture. I have been running an accumulator for many years and use a swivel fitting from that spot to the accumulator. Why would you need adapters etc?
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 01-09-2021, 10:02 AM   #14
Chuck Gallagher
Liked 134 Times in 28 Posts
Drew;
If you have enough iron at that location to safely drill and tap the threads needed to install a large enough fitting so that the oil passage is the same size through and on both sides of the fitting and your lines have adequate clearance then no problem. An oil filter adapter is just one way an accusump can be easily installed on the filtered oil side with out creating a bottle neck to smooth oil flow or machining the block.
Chuck
Chuck Gallagher is offline   Reply With Quote
Old 01-09-2021, 05:49 PM   #15
rboyle
rboyle's Avatar
Liked 590 Times in 163 Posts
Originally Posted by Nmbr1GMfan View Post
Brett, My small block doesn't have that.
J have a Dart Little M and there is a plug on the drivers side near the bellhousing that is used specifically for accumulator return line according to Dart
Old 01-09-2021, 09:56 PM   #16
Nmbr1GMfan
I didn't get the little M, I have the SHP block (25lbs lighter).
Todd Greene
