Old 01-31-2021, 07:54 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Cowl area at back of hood
I have 98 camaro that I run in stock eliminator. Can I cut out part of the metal cowl area to make getting the engine in and out? My rubber seal that seals against hood in rear is not in the best shape. Can I remove it? I will keep the plastic part that goes all the way across. Just not much room to get the engine out without having to turn it sideways. Pictures would be nice.
Kdw1403 is offline   Reply With Quote
Old 02-01-2021, 03:42 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Cowl area at back of hood
Nope, don't believe that modification is legal. You might try a little mis adjustment on the hood to get the back up, but no cutting.
Adger Smith (Former SS)
Old 02-01-2021, 10:13 AM   #3
nhramnl
Liked 358 Times in 83 Posts
I have seen numerous Camaros, Firebirds, Cavaliers, G5s, etc. with a removable windshield washer "tray" and plastic leaf screen. Take a look at almost any MPR-built car and you'll see what I'm talking about. My Cavalier's tray and screen are completely removable, right to the base of the windshield, and when they are back in place, the car looks completely unmodified. Makes a HUGE difference in engine removal and re-installation.
Old 02-01-2021, 11:25 AM   #4
FED 387
Liked 333 Times in 180 Posts
fabricate a piece of the size of the area that you are removing and keep it place with DZUS fasteners
Old 02-01-2021, 11:37 AM   #5
Liked 5,137 Times in 1,960 Posts
You can't remove the rubber lip/ seal from the back of any hood...in case anyone looks.
Old 02-01-2021, 12:39 PM   #6
SSDiv6
Only allowed in Super Stock class, not Stock class.
Old 02-01-2021, 01:25 PM   #7
nhramnl
Thanks for the clarification. I assumed that, since all of the removable panels I've seen have been fabrication-modified such that they look virtually unchanged, and can be bolted right back in (essentially only making a non-removable piece removable), they would be OK. Apparently not. Getting the engine out of a 4th Gen Camaro/Firebird must be brutal, when you can't get the cowl out of the way!
Old 02-01-2021, 01:56 PM   #8
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
When I had my ‘97 Firebird Stocker I made an extension for my engine hoist and cut the front of the square tube to clear the area behind the hood.
Also attached the hoist to the engine as tight as possible to the intake.
I left the hood on and just propped it up higher.
Had to turn engine sideways a little and removed probably the water pump and distributer and maybe balancer. It’s been a while so I don’t recall exactly.
I did add a lot of weights to my engine hoist to counter the extension and keep it from flipping over.
I saw that happen by some guys pulling a BB out of an MPR built Firebird and luckily no one was hit other than some minor damage on the cars nose.
I know there is a plate made to attach to those engines for lifting but I dreamed up something else and think it was a spreader bar with chains that I bolted to 4 exhaust port flange holes.
The cowl stuff just got pushed out of the way as needed.
Rich Biebel
S/C 1479
Stock 147R
Old 02-01-2021, 05:35 PM   #9
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
When I had my 97 Firehawk , I always removed the whole front cradle through the bottom . I made a rolling cart that carried the cradle , and lifted the body up with my hoist . I have seen video's of people lifting the front of the car up using a cherry picker . What is so nice about this method is the engine, trans , headers and complete front suspension come out together , by undoing a minimal number of easy to get at bolts .
Old 02-01-2021, 06:30 PM   #10
KRatcliff
Liked 534 Times in 143 Posts
I have taken mine out from the bottom and can do it far quicker from the top using one of these. I disconnect the hood struts, bungee it back, and pull the plastic pins holding the cowl in place.
https://tpis.com/products/9_hhk299?v...28342560555080
KRatcliff is offline   Reply With Quote
