Old 02-02-2021, 07:25 AM   #21
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Default Re: Canton accusump vs. Moroso accumulator
So.....without a regulated pressure switch, when you turn engine off, doesn't the pressurized oil in accumulator pump back to the oil pan? If so, no pre-oiling at start up, (how important this is, is debatable) would happen as the accumulator is empty.
SC 707Y
Dano is offline   Reply With Quote
Old 02-02-2021, 07:35 AM   #22
Darcy Clarke
Liked 529 Times in 36 Posts
Without a switch or manual valve the oil pressure will bleed off. Not having a switch to me is a waste of time as it defeats the purpose.
Darcy Clarke
A/SA SS/EA
Darcy Clarke is offline   Reply With Quote
Old 02-02-2021, 10:30 AM   #23
Nmbr1GMfan
I think the pre-lube feature is a secondary feature to the accumulator. I would guess most are utilizing it's capabilities as a safeguard against oil starvation.
Todd Greene
Old 02-02-2021, 11:35 AM   #24
curtis reed
Liked 125 Times in 59 Posts
I run the electric valve on mine but I don't run the pressure switch.
curtis reed is offline   Reply With Quote
Old 02-02-2021, 12:01 PM   #25
mishsc
Thank you all for your comments and opinions. Your help is much appreciated.
mishsc is offline   Reply With Quote
