Liked 2 Times in 2 Posts
Ok dumb question, how much power is there in having the crank machined +.015 on a sbc. Is it actually worth the expense? Is there another purpose for this other than added stroke?
Thanks, John Beasaw |
Liked 13 Times in 2 Posts
Yes.
Liked 49 Times in 15 Posts
If you are making 1.5 HP per cubic inch, in theory you add 1.5 HP for every cubic inch you add.
A correctly stroked crankshaft will also correct a poorly indexed crankshaft.
Dean Feiock -- Stock 5002 |
Liked 327 Times in 121 Posts
I personally have found cubic inch to be worth nothing with induction, comp, and cam being the same in a modest bracket race situation.
Liked 8,170 Times in 1,536 Posts
It depends, if you want to run with the BIG DOGS, ...you can’t leave ANYTHING on the table.....
Liked 2,361 Times in 558 Posts
It's the thing you do when you want that "LAST" little bit......
On a Stock or SS we always run .013 stroked crank.
Has to be indexed anyway at least with all our Mopars I have seen 10 stockers in class within less than a Tenth of a second One year in Class in Denver Natl's = we had a race decided by .0001 Plenty of Class racing with an hundred or two!
Liked 535 Times in 110 Posts
Dean is correct, you're effectively killing two birds with a single stone!
Jim Kaekel 3836 STK |
Liked 10,852 Times in 2,254 Posts
Adjusting stroke will not correct index. To fix index try to find a grinder, machine, with new or rebuilt chucks that has index stops at 90*. After its index always check TDC and zero on damper. Rolling the crank to get it to "clean up" @ .020" under while stroking it .014" will some time change the relationship between the two. To check quick index #1 and #6 should arrive at TDC at the same time using two dial indicators.
We use to grind cranks for Kuntz & Craft years ago. In fact we have lost to a 428 heads up with a crank we stoked and indexed for Jim and Keith. |
Thanks for the insight. I knew the rules allowed indexing/stroking, i just wasn't sure if there was a large enough advantage vs expense.
As for my combination i don't have a budget to run with the big dogs. Game plan is .40-.50 under in the heat just to play. Thanks John Beasaw |
