Old 02-10-2021, 06:40 PM   #1
Liked 10,713 Times in 2,230 Posts
Default Over Staging
That will speed up the racing.
Old 02-10-2021, 07:29 PM   #2
Not So Fast
Liked 11 Times in 4 Posts
Default Re: Over Staging
Does anyone know the reason for the policy change from NHRA?
Not So Fast is offline   Reply With Quote
Old 02-10-2021, 08:36 PM   #3
G Schenck
Liked 81 Times in 35 Posts
I thought that was always the rule.
Greg
G Schenck is offline   Reply With Quote
Old 02-10-2021, 08:38 PM   #4
FED 387
Liked 333 Times in 180 Posts
I think some guys are checking the rollout(depth) to see just where the last staging light "really" is OR how far in can I go before I'm in danger of red lighting or deep staging
Old 02-10-2021, 09:47 PM   #5
Cotten
Liked 564 Times in 70 Posts
I agree with Gregg.
I thought that had been the rule for a long time.
Cotten is offline   Reply With Quote
Old 02-10-2021, 10:17 PM   #6
Liked 5,121 Times in 1,952 Posts
Wink Re: Over Staging
Not sure what the new rule means..
So, if a guy accidentally burns out across the line, he's out?
If a newbie doesn't courtesy stage, he's out?
If a Jr. Dragster or Pro deep- stages, they're out ? Oh wait, they CAN deep -stage.
Old 02-10-2021, 10:33 PM   #7
Mike Gray
Mike Gray's Avatar
Liked 685 Times in 196 Posts
Greg
So did I. I have seen guys accidentally turn on both stage lights before their opponent stages and the starter backed them out to re-stage, but if you went in too deep and turned out the top bulb you were out.
Mike Gray is online now   Reply With Quote
Old 02-10-2021, 10:57 PM   #8
MR DERBY CITY
Liked 7,938 Times in 1,519 Posts
I saw a stocker roll thru, turned off the top bulb BUT was not Redlighted because the opposing racer only had one bulb on ..Needless to say, the offending racer backed up VERY QUICKLY .....
Old 02-10-2021, 10:59 PM   #9
GTS340
Liked 1,344 Times in 410 Posts
Like Gregg and Mike I thought they removed deep staging and turning on both light then backing out. I think it use to mess up the staging timer. Every time I see it now I question why the same folks do it on a normal routine and are allowed. Usually I have to wait to make sure my dial is correct before I pre-stage as the pair in front are still running their race. I try not have a senior moment by mistake. Many years ago we did a couple dry hops after the burn out.
Paul Haszlauer
Old 02-11-2021, 05:20 AM   #10
SGSST109E
Liked 126 Times in 61 Posts
I was watching the feed from Orlando when a stocker went in to deep during eliminations and didn't get a red. I thought he should have gone red. Maybe people questioned why not.
SGSST109E is offline   Reply With Quote
