Old 02-22-2021, 07:37 PM   #1
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default Trailer Floor Coating Recommendations
Looking for recommendations. Anyone use Tekton 64?
Joe Marcinowski 3377 STK
Joe Marcinowski is online now   Reply With Quote
Old 02-22-2021, 10:37 PM   #2
Gmirza
Liked 253 Times in 95 Posts
Default Re: Trailer Floor Coating Recommendations
I used epoxy shield on mine. Two coats, the stuff leaves a nice hard surface and any fluid leaks just wipe right off. After two years it shows very little wear. And it’s available at any of the big home improvement stores.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 02-23-2021, 03:26 PM   #3
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
I agree with the epoxy paint. Also. any garage floor paint will hold up spills and drips. Make sure the floor is clean and grease free to get good adhesion, cut your edges in with a brush and go at it with a roller. The paint will set up within 24 hours.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 09-30-2021, 06:56 PM   #4
rod
Liked 20 Times in 15 Posts
how does this stand up to hot tires. does the tire leave imprints or peal off the paint?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 12-12-2021, 11:59 PM   #5
GTX JOHN
Hot Tires eventually leave traces no matter what paint we use or
how long we let it sit and cure!
John Irving
741 Stock
741 Super Stock
Old 12-13-2021, 12:15 AM   #6
Jeff Stout
Liked 706 Times in 283 Posts
Small pieces of diamond plate in area of tires when sitting helps
