Old 02-27-2021, 11:52 AM   #21
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Decal adhesive remover
Originally Posted by btrc View Post
Al, Where did you get the Goof Off Pro Strength?
PS. I got the tires and gave John the $. Thanks
Bob, Ace Hardware had the Goof Off Pro Strength. It's a xylene and acetone mix. It evaps fast so you have be quick-like-a-bunny with the scraper. It took all of a 1 pt. can to get all those years of decals off the 'Black B - - - h' (Ron's favorite name for it ).
Don't let John stick you with the lunch check this week as some sort of 'handling fee'.
Thanks! -Al
"That'll never work....."
Old 02-27-2021, 01:18 PM   #22
older racer
Liked 68 Times in 26 Posts
hi, I use a hair dryer, heat decal, peel it off, then i use turpentine to remove and glue left on, it removes it easily. afterwards, I'll rub some polish on spot to bring back the shine. just food for thought.
older racer is offline   Reply With Quote
Old 02-27-2021, 10:10 PM   #23
monte385
Liked 27 Times in 19 Posts
If your paint is acetone safe that works pretty good.
monte385 is offline   Reply With Quote
Old 03-08-2021, 08:58 PM   #24
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Ended up using a product called Goof Off Pro Strength. It softened the adhesive and then a scraper rolled the adhesive off. These little scrapers are pretty slick...different shaped corners helped conform to the curves the body has.
Thanks for the suggestions. -Al
Where did you get the scrapers?
Mike Moller
NHRA 203 Q-R-T/SA
Old 03-08-2021, 10:35 PM   #25
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Originally Posted by Mark Ruset View Post
You may want to try a heat gun or hair drier, warm the panel up a bit and use a plastic razor blade
, or a plastic squeegee. I would follow it up with some rubbing alcohol.
Yes i would have to agree on using a hair dryer, plastic razor blade & some WD 40.
Just take your time and don’t overdue the hair dryer if it’s on high n hot.
"Pistol" Pete Dutko
Old 03-09-2021, 10:32 AM   #26
Alan Nyhus
Mike, I snagged those in the kitchen section at Target. -Al
Old 03-09-2021, 12:08 PM   #27
btrc
Liked 84 Times in 42 Posts
They are used for smoothing out the caulking on counter tops and bath tubs, etc.
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 03-11-2021, 04:29 PM   #28
Chevy55
Banned
Liked 179 Times in 89 Posts
There's nothing better that this!!
3M Stripe Off Wheel Adhesive Remover Eraser Wheel Removes Decals, Stripes, Vinyl, Tapes and Graphics
https://www.amazon.com/dp/B00063VT0G...v_ov_lig_dp_it
Chevy55 is offline   Reply With Quote
Old 03-11-2021, 06:02 PM   #29
Really? How much did that deal cost you? I'll bet my method is cheaper.
BTW, only 3 pages? I'm sure we can drag it out to 6. ;-)
Old 03-11-2021, 07:28 PM   #30
GTX JOHN
I just stand close and urinate directly onto them.
Of Course I am Diabetic and have a very strong prostate!
John Irving
741 Stock
741 Super Stock
