Old 03-16-2021, 04:50 PM   #21
mannymen
Liked 13 Times in 7 Posts
Default Re: Automatic Shifter Options
Never liked the turbo action and how it slides from Neutral into 1st for T-400 reverse application. You never really know if it's truly in first where it should be, whereas a ratchet is in or its not.
N/A
mannymen is offline   Reply With Quote
Old 03-16-2021, 07:49 PM   #22
Gmirza
Liked 253 Times in 95 Posts
I know for the 727/904 shifter they offer two gates. One has a positive stop for first. The other, like you stated, can be used with an air shifter. I agree, you have to be careful with that gate. The other one is nearly fool proof when manually shifting.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 03-16-2021, 10:35 PM   #23
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
If you ran a glide you couldn't beat a Perry shifter...gsa612
Old 03-17-2021, 11:19 AM   #24
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
B&M Quick Silver. Forward or reverse pattern.
NHRA and IHRA approved.
Using mine 20 years. Just changed cable once. It fell on exhaust. My fault.
chris ok is offline   Reply With Quote
Old 03-18-2021, 12:10 AM   #25
Chad Fergen
Liked 24 Times in 12 Posts
I'd say 90% of the cars I work on or build use the TurboAction Cheetah shifter ,
It's a simple design and if I'm not mistaken ,the base component has aircraft origins .
I've seen 30 year old Cheetah's that still work flawlessly.
Had one in my own Stocker .
I have been looking at these and it appears they are out of stock. In all fairness I only checked Jegs and Summit. I believe the part number is 70012. Heading to Vegas next month. I might have to focus and squeeze the trigger for 3rd.
PS, The BBB is cool but out of my pay grade.
Chad Fergen is offline   Reply With Quote
Old 03-18-2021, 09:31 AM   #26
Alan Nyhus
Liked 800 Times in 237 Posts
Chad: just put a B&M Pro Ratchet in it and Rule the World! -Al
"That'll never work....."
Old 03-18-2021, 01:18 PM   #27
Tom Goldman
Tom Goldman's Avatar
Liked 887 Times in 239 Posts
Chad ,you can buy direct from Turbo Action . Jegs ,Summit and others are not stocking a lot of parts and are drop shipping direct from the manufacturer.
Although the prices might be slightly higher and you'll pay shipping ,at least you can get the part.
I've had to go this route with a lot of parts in the past year.
Old 03-18-2021, 02:07 PM   #28
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
I'm also a fan of B&M pro ratchet.
Terry
outlaw is offline   Reply With Quote
Old 03-18-2021, 11:06 PM   #29
Eman
Liked 133 Times in 76 Posts
With a forward pattern 3 spd I've messed up the squeezing the lever, the worst is when you ease off the lever and end up pushing it to neutral. I've used the B&M Pro Ratchet and it's a great shifter. Turbo Action is good and does away with squeezing the lever.
Old 03-19-2021, 11:41 AM   #30
Race Clean
Liked 129 Times in 53 Posts
Originally Posted by steven reynolds View Post
As I have been told, "make sure all bolts are tight, use the correct levers, shift arms, if you have reverse pattern valve body, make all adjustments in high gear, if this is done right then the rest is right"
That's about all I know about adjusting the shifter itself and it did work for me
Steve
Dug out the instruction sheet for MY PPP today, it clearly states that final adjustments should be done in Second gear. That is on a P-R-1-2-3-N PATTERN
Stop global whining
Race Clean is offline   Reply With Quote
