Old 03-27-2021, 07:49 AM   #11
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: SBC 461 heads
Originally Posted by Greg Reimer 7376 View Post
Seems like the 461 head is only legal up to about 1966 cars, the 462 head is legal from '61 to 68, the 041 head is legal from '61 to '70, since most new stocker projects are newer than that, the 041 head from '69-70 would be a better head to get, since it has a far broader range of applications.
The 291 and 186 heads also work well. -Al
"That'll never work....."
Old 03-28-2021, 11:41 AM   #12
Jim Cimarolli
Liked 166 Times in 46 Posts
Thumbs up Re: SBC 461 heads
Alright, I have a 3782461 head that someone told me was a 461X casting. I don't see an X on it anywhere near the casting numbers, I remembered seeing 461X heads that had the X at the end of the casting number. This head has a date code of G 111, but it does have a small X on the bottom of the head right below the water passage near the deck surface and between the intake gasket surface at the water crossover passage. It has 1.940 intakes, 1.500 exhausts, and looks like an original old head that might never have been apart. Where was the X that designated this as a 461X casting?
Where you see the x on your head is correct.
Jim Cimarolli is offline   Reply With Quote
Old 03-28-2021, 01:19 PM   #13
Mike Jones
Liked 684 Times in 289 Posts
Like this...
Old 03-28-2021, 01:40 PM   #14
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: SBC 461 heads
That's it!! Thanks for the picture. Anybody have use for this head? I only have one.
Old 03-29-2021, 08:16 AM   #15
Bobby Lundholm
Liked 127 Times in 49 Posts
Seems like the 461 head is only legal up to about 1966 cars, the 462 head is legal from '61 to 68, the 041 head is legal from '61 to '70, since most new stocker projects are newer than that, the 041 head from '69-70 would be a better head to get, since it has a far broader range of applications. It's like the 993 casting for the '70's cars. Legal replacement for a lot of cars, for sure.
The 462 is available to use in 1969 as well.
350/300 - 3917291,3927186,3947041,3991492,3767462,3890462,39 17292
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 03-29-2021, 09:59 AM   #16
Todd Bailey
Liked 33 Times in 17 Posts
After Lee Shepherd "discovered" these heads, the race was on to find a pair, especially if you raced in the Super Modified classes as well as the Econo dragster/altered classes.
Todd Bailey is offline   Reply With Quote
