Liked 7 Times in 5 Posts
Building a Malibu for stock . what bolt on rear suspension mods is everybody using. Any help appreciated . Mike
Liked 28 Times in 9 Posts
I would start with a real good set of adjustable rear shocks and initially tighten the right one more than the left ( you will have to test to determine what settings work best ) . The rear sway bar is critical and will need to be adjustable as well ; the best I found was HRpartsNstuff (330) 947-2433 . Good luck with your project .
#3 | |
Liked 10 Times in 4 Posts
A rear sway bar is the best investment you will make. I bolted on the Xtreme Anti-roll Bar from BMR Suspension and it removed all body twist from my car. However, it does add about 25 pounds.
Owen S. Birkett Stock/Super Stock 4106 |
Liked 271 Times in 107 Posts
They are pretty simple and inexpensive. Basically adjustable upper trailing arms to adjust pinion angle. Box in the lowers for strength. Solid or poly urethane bushings. Adjustable shocks,and anti roll bar or airbag in pass side coil spring to control rollover. Some good products and info over at maliburacing com
Liked 535 Times in 110 Posts
Like Brian F. said above, the HR Parts 'n' Stuff anti-roll bar is great, and it's made from hollow chrome moly tubing and isn't very heavy. There are alot of nice upper and lower control arms out there from alot of companies.
Jim Kaekel 3836 STK |
Liked 321 Times in 63 Posts
Some of the aftermarket lower control arms will change the wheelbase a little. Be sure to check.
Bob Shaw V/SA 515 |
Those are the ones I use ;-)
Liked 140 Times in 51 Posts
Stock boxed arms with bushings and comp engineering shocks with an anti roll bar are good to 10 s. Some use the HR arms instead of boxing and bushing the stockers. The HR Anti roll bar is the top of the food chain but lots of Buick guys use the old ATR bar. This is a stock mount style and works very good. Stock GN springs go low 9s.
http://www.aggressiveauto.com/proddetail.asp?prod=SU00
The more people I meet the more I like my dog Kevin |
