Old 03-26-2021, 08:25 PM   #1
rod
Liked 20 Times in 15 Posts
Default index plugs ?
SBC angle plug heads. does the plug gap go towards the piston or the head?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 03-27-2021, 10:15 AM   #2
richie 2
Liked 205 Times in 93 Posts
Default Re: index plugs ?
towards the piston. keeps electrode away from the piston.
Old 03-28-2021, 08:19 AM   #3
SGSST109E
Liked 126 Times in 61 Posts
The reason is to keep the gap from closing if the piston were to hit the grd strap
SGSST109E is offline   Reply With Quote
Old 03-28-2021, 11:05 AM   #4
rod butcher
Liked 132 Times in 27 Posts
thanks Rod in AZ
Electrode strap should be between 11 and 1 o'clock Use a marker to put a line on porcelin and you may need 12 plugs to get all 8 indexed correctly..
rod butcher is offline   Reply With Quote
Old 03-28-2021, 01:04 PM   #5
MR DERBY CITY
Liked 8,202 Times in 1,536 Posts
If the plugs are indexed incorrectly, you will probably know after the first run down the track. That’s how I found out ......As usual , ROD BUTCHER is correct ......I always buy a ten pack of plugs....
Old 03-28-2021, 02:38 PM   #6
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
If with 10 plug you can't get them index correctly, Moroso sells indexing washers.
Moroso 71910 - Moroso Spark Plug Indexing Washers. They have 4 different washers
Bob
Old 03-28-2021, 06:01 PM   #7
terry1
Liked 24 Times in 13 Posts
Smile Re: index plugs ?
Bob, the washers you have/use, are they the ones that are sort of hollow/concave?
What I mean is the ones I had were hard to "seat" ; I never really knew if
my plugs were tight or not.
Terry K
terry1 is offline   Reply With Quote
Old 03-28-2021, 06:19 PM   #8
Bob Lasko
Bob Lasko's Avatar
Terry K
Terry,
When I use them I tighten the plug till tight. The one's that I use are not hollow.
Bob
Old 03-28-2021, 06:20 PM   #9
richie 2
two kinds of index washers avialable.... flat or tapered. flat for early heads and tapered units for taper seat style plugs...
Old 03-28-2021, 06:30 PM   #10
Bob Lasko
Bob Lasko's Avatar
I have the tapered plugs
Bob
