anybody know why jerry davis is on the dq list at houston?
Liked 346 Times in 126 Posts
it just could be as simple as not passing the fuel piss test
Liked 292 Times in 92 Posts
They tore down 3 cars, Jarrod Granier and Terry Emmons got through, heard that Jerry had a problem with cam and heads??? I guess if you attend a Divisional Race or National in Div 4 'Land" you better be right or you might be toast. It ought to be interesting at Belle Rose next week, as Mr. Roberson will be on the prowl, and Pat has lots of empty shop space with engine hoists to spare. Have already heard of a "rod and piston" that is suppose to be coming out down there, wonder who will win the lottery???
Ain't it great Later RJ |
Liked 444 Times in 145 Posts
We should have a best no name contest!
Bruce Noland 1788 STK |
Cam lift checked .010 safe side with my check lifter during the inspection but Bruce would only accept an NHRA lifter. They used a big block Mopar lifter which is different push rod seat which caused an increase. By the time I figured out what was going down I was gone.
5 cc's of the port volume was because of the change from the stock tulip valve to a cut down Manley nail head valve and some more for the new any valve job. Thanks Jerry |
#6 | |
Chad Rhodes 2113 I/SA Last edited by Chad Rhodes; 03-30-2008 at 08:48 PM. |
Liked 1,908 Times in 427 Posts
The location of the pushrod seat directly effects the effective length of the pushrod. Now, a rocker arm is NOT constant ratio. The ratio of a rocker arm changes constantly as the ends rotate around the fulcrum. Raising or lowering the pushrod seat raises or lowers the pushrod, changing the effective ratio of the rocker at various points.
Alan Roehrich 212A G/S |
Liked 10,850 Times in 2,254 Posts
If the lifter seat is and or the lifter is taller than the one used, the adjustment screw moves closer to the fulcrum changing the lift at the valve.
On head runner cc there is no rule in stock. |
I was told by 3-4 NHRA tech guys that they are pouring Stock heads at random, and collecting data to make a database.
Lifter push rods angle on a small Mopar and the Hemi's are very bad. If the correct lifter (with lots of clearance around the push rod)is not used the pushrod will hit the side of the push rod seat and cause the push rod to raise off of it's seat which will increase the lift.
