Old 04-12-2021, 07:56 PM   #1
Wild306
Default 1969 mustang. Need help with class options. Stock? Gt?
I have a 69 coupe. I determined that my 351w isn't a great combo, probably not the 302 2bbl that would be m stock either. And I don't want to mess with 428s either. I do not know a whole lot about super stock gt, but can I use a newer 302 for example with my weight and use that? What if its a 80s fuel injection engine? Does it need to use original style induction, ? Gt fi? I'm just trying to find a direction. Thanks.
Wild306 is offline   Reply With Quote
Old 04-12-2021, 08:01 PM   #2
4284spd
4284spd's Avatar
Default Re: 1969 mustang. Need help with class options. Stock? Gt?
I would look at GT with the 352CJ set up from 2010.
Bob Smith
Old 04-12-2021, 08:17 PM   #3
Wild306
Isn't that a 302 based pushrod engine?
Old 04-12-2021, 08:24 PM   #4
dwydendorf
dwydendorf's Avatar
Liked 19 Times in 7 Posts
There are more options with a 70 mustang, 351c with autolite carb is a possibility. You have to decide if it is stock or super stock. Gt is only in super stock. It is not hard to make a 69 into a 70.
ss/gt 93 t-bird
dwydendorf is offline   Reply With Quote
Old 04-12-2021, 10:37 PM   #5
Marc White
Liked 29 Times in 9 Posts
What combo is the all black SS/GT mustang I think from the northwest. Beautiful car.
Marc White is offline   Reply With Quote
Old 04-13-2021, 06:26 AM   #6
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
Your options to run GT are wide open. You should go onto classracerinfo.com, and start playing around with engine combos. Dickie Lux is running the 352 pushrod engine from the 2010 Mustang Cobrajet in his car, looks like a pretty good modern combo. Duane Eiskant is running the 73 351c combo in his 85 mustang. Other factors to consider are wether you have or want to put a cage in the car. Thay may limit you on what you want to run.
Good luck and have fun
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 04-13-2021, 08:30 AM   #7
Wild306
I already have a cage. 351c would be neat. I would like to.pick a combo that doesn't use a weird carburetor like my 351w had.
Old 04-13-2021, 08:15 PM   #8
Rory McNeil
I believe that you are talking about the black 69 Mustang notchback, that belongs to Darrell Dietz, from Alberta Canada. I believe it used to be ran with a 428 Cobra Jet in Super Stock, but now runs in SS Factory GT, with a late model DOHC Cobra Jet engine.
NHRA 6390 STK
M/S 85 Mustang
Old 04-13-2021, 08:20 PM   #9
Rory McNeil
I belive the 1970 351C 4 barrel engine is still required to use the "weird" (your words), Autolite 4300 4 barrel carb, which was also used on 69 351W engines, but the 71 & 72 351C can run a Holley carb. The 70 351C engine also has a smaller cam than the 71-73 versions, along with a higher factory HP rating.
NHRA 6390 STK
M/S 85 Mustang
