Old 04-28-2021, 05:17 PM   #1
Liked 10,926 Times in 2,257 Posts
Default Stocker 383/440 cams
Some new some used, Comp, Isky, Lunati,GK
$100 each
Old 04-29-2021, 12:13 AM   #2
GTX JOHN
Liked 2,493 Times in 700 Posts
Default Re: Stocker 383/440 cams
Larry:
Can you E Mail me specs on cams
The Brand and if new or used
I will probably buy at least a few.
Racer7411@yahoo.com
John Irving
741 Stock
741 Super Stock
Old 04-29-2021, 12:35 AM   #3
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
Might be a dumb question but are these solid lifter cams?
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 04-29-2021, 07:09 PM   #4
We ran these cams with shubecks or Hill lifters, only three set made, Jerry Newsom, Mine and the "Truck". lifters had .005 movement to satisfy the rule as written then. I still run the limited travel hyd.
John They are all .467/ .483 cams. we have a set of '70 rockers to change to .455 /.470 from the 71 numbers
Old 04-30-2021, 06:25 PM   #5
theman440
theman440's Avatar
Another dumb question - how well would one of these cams work in a street car?
Jeff Dudgeon
"the Flying Brick"
Old 05-01-2021, 09:37 AM   #6
It might be a good "Dairy Queen" cam. I never drove anything on the street with one of these cams but for $100.00 how can you go wrong. the best thing about a used cam is it's broke in.
I would recommend dialing the cam it with a degree wheel and checking valve clearance at split overlap to make sure the piston is out of the way.
Old 05-02-2021, 01:20 AM   #7
GTX JOHN
Are the Isky cams new?
If so I will buy them if the are set up for Hyd. Lifters
John Irving
741 Stock
741 Super Stock
Old 05-02-2021, 09:29 AM   #8
I will look today
Old 05-02-2021, 06:25 PM   #9
Isky brand new in the box has never been out been unwrapped
109* 1651 on the box.
TCS, just a guess, it might stand for Tri-City Special. Number on the box 041560-4 109. When we ground cranks I removed the fuel pump lobe.
Old 05-02-2021, 09:46 PM   #10
GTX JOHN
I will buy the Isky
PM me you contact #
Thank
John Irving
741 Stock
741 Super Stock
Search this Thread:
Advanced Search
