Liked 5 Times in 5 Posts
Is it possible for a car with leaf springs,Cal-Tracs and stock shocks to pull to one side under acceleration of one of your shocks is bad?
Liked 1,948 Times in 589 Posts
I guess its possible but I would be looking at other things first. Check to see if the rear is square in the car. would be the first thing I would check. While you are under there you can loosen the bottom of the shocks and run them through the stroke to see if they feel like anything is going on with them. Check the adjustment on the bars to see if they are neutral. I would also give Caltracks a call to see what they have to say.
Mike Pearson 2485 SS |
Liked 706 Times in 283 Posts
Make sure housing is on spring perches correctly. Also brackets on spring eyes could be flexing or cracked welds.
Liked 920 Times in 259 Posts
Scales will help diagnose what is going on. Especially if the car had previously been baselined, numbers recorded, worked ok, and is now misbehaving.
Even if this wasn't done, corner weights are useful. Bad shocks will make a car do stupid things. As stated, a good visual inspection is the first step. |
All the Above.
Also check everything for tightness and condition of all suspension stuff.
Liked 92 Times in 29 Posts
First thing I would check is rear tire diameter to see if they’re the same.
Liked 23 Times in 13 Posts
what type of leaf spring also check your settings on bars, could of tighten or loosen up, this would cause it to pull.
Frank Bialas 1570 STK |
#8 | |
Liked 805 Times in 341 Posts
Chased a lot of things including taking it to the chassis shop and correcting some minor things. It turned out it was a bad slick. M/T Radial, old but with not that many runs. So you might try a different pair of tires if you have not done so already. |
Hey 340Cuda I do have some M/T radials that are old with about 20 passes on the car right now
That sure could be it.
I have never heard of anyone else having this problem but I would sure try changing them out. |
