Old 05-30-2021, 03:32 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default 1998 GMC K3500 7.4L vibration
I've owned this truck since almost new (less than 3000 miles) From day 1 it has had a very slight vibration around 2200 Rpms. It was a executives vehicle. He got upset about the vibration. And dumped it at the dealer I worked at.. The vibration never bothered me. I just figured it was something internal and eventually it would get worse and I'd either rebuild it and balance it or put another engine in it. Fast forward 20+ years and 150,000+ miles. All the sudden one day my buddy borrows to haul calves. And it gets bad enough to be concerning. While checking it out I noticed that it seemed like the engine moved a lot. And the drivers side motor mount may be starting to bad. So I get one and I'm hurt so my buddy comes over to my shop and puts it in. To my surprise it 100% cured the vibration. I was like I've been driving this thing for 20+ years like this and it was just a motor mount. Or so I thought. 3 months later out of the blue its back with a vengeance. But its different its vibrating on deceleration where before it was on acceleration. Even sitting still in park it vibrated with the rpms going up not down. We look at it and it seems the right motor mount may now be doing the same as the left. If you've ever changed motor mounts on one of these things you know why both were not changed at one time. Its not a fun job. So my buddy comes over and changes the right motor mount. Its cured again. Or so we thought. 3 days and a couple hundred miles later its vibrating again. So either were getting bad parts that look perfectly fine. Or something else is wrong. If anybody has any ideas before we fight another set of motor mounts into this thing I'm all ears.
Old 05-30-2021, 08:04 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Default Re: 1998 GMC K3500 7.4L vibration
Did you check the transmission mount and driveshaft while your at it.
Old 06-03-2021, 07:44 PM   #3
Mark Ugrich
Liked 71 Times in 38 Posts
Just a thought, but did you try unbolting the torque converter and running the engine?
Old 06-06-2021, 02:27 PM   #4
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
I recall a GM service bulletin that addressed engine vibrations, It had to do with adding a shim type spacer between the block and mount. I believe the issue had to do with alignment of the motor mounts. I don't recall what years it was related to. On another note make sure that the motor mount bolts going into the block are not bottoming out before the mount is completely tightened,
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
