Old 05-30-2021, 03:10 AM   #11
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Default Re: Rear Coilover Spring Rate Help
I bought a set of D/A Koni's Bickle valved in the late 90's. He suggested a 175 on this all steel Nova.
If you look at his spring recommendations in one of his catalogs, 1500-1800 rear weight he suggests a 175.
I did put a 125 spring on this to run some local 370 Pro Tree races. It did work for the fast tree, however it acted more so than previously, like it needed a ARB. Ladder bar sbc 10x28 bias, 3200 lbs.
Eibach or PAC coilover springs are the good ones, if you can find PAC, they've stopped producing , coil springs.
I just bolted a set of PAC 165 on this, i bought and made one hit on in 2017, went 1.28 60ft last car down on a Thursday night test n Tune prep n/a sbc. 1550 lbs on back tires.
Not criticizing anyone's suggestions here, just stating my experience, light vs heavy spring.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 05-31-2021, 01:05 AM   #12
CMcAllister
Liked 920 Times in 259 Posts
OP stated he was using a 19" shock. I made some assumptions from that as far as shock travel, installed length at ride height, spring free length and compressed length at ride height, etc. All of which make a difference.
Old 06-01-2021, 01:29 PM   #13
MROD7007
Mike Rietow
Give me a call when you gat a chance. I would like to discuss further.
Mark
210-392-9902
MROD7007 is offline   Reply With Quote
