Old 06-07-2021, 12:52 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default Cleaning Aluminum valve covers?
Want to make valve covers look nice and new looking again. Not wanting polished but mild corrosion, and dull removed. Some kind of blasting, chemical? Thanks. Sorry tried posting picture but it is to large from my phone
Old 06-07-2021, 09:31 PM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Cleaning Aluminum valve covers?
Get some new Glass Bead from MSC or other similar supplier.(But clean all the oil out of them 1st or the glass will pack into wherever its wet.) After a few uses the glass will break down and get real powdery which will change the appearance of what you are blasting.
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 06-07-2021, 11:30 PM   #3
FED 387
Liked 333 Times in 180 Posts
NAPA aluminum brightener----nasty stuff so follow directions carefully---wear gloves and eye protection---- DO NOT GET IT ON YOUR SKIN OR BREATH THE FUMES ---it will burn you has acid in it---FED 387
Old 06-08-2021, 07:34 AM   #4
BillK
Liked 30 Times in 17 Posts
See if there is anyone around that does soda blasting. It will make them look very nice with no chance of engine damage like you have with glass beads.
Bill Koustenis
BillK is offline   Reply With Quote
Old 06-08-2021, 11:30 AM   #5
Liked 5,137 Times in 1,960 Posts
I've used it, and the Purple Power version (not the purple cleaner).
You have to be careful. It turns some material dark, rather that bright.
Old 06-08-2021, 05:35 PM   #6
65signet
Liked 49 Times in 22 Posts
Wet blasting is amazing what it can do to the finish
Name:	Valve covers .jpg
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
