Old 07-23-2021, 02:49 PM   #1
steve4speednova
Default Shocks
Is anyone out there using QA 1 piggy back shocks, and what do they think about them?
steve4speednova is offline   Reply With Quote
Old 07-25-2021, 09:47 PM   #2
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Default Re: Shocks
Haven't seen them yet, is there a schrader valve visible?
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 05-16-2022, 01:35 PM   #3
BobbyH
Liked 62 Times in 19 Posts
Default Re: Shocks mounting nuts
Hello all ,what is every one using instead of the stock j-nuts to mount Santhuff shocks to the GM control arms on A,F bodies?
BobbyH is offline   Reply With Quote
Old 05-16-2022, 04:35 PM   #4
SSDiv6
Reach out to Marty Rinehart or Marty Jr at Rinehart's Performance and they will get you all set up.
https://rinehartsperformance.com/
(717) 880-6716
Old 05-16-2022, 11:01 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Default Re: Shocks
The best solution and the strongest is to install an AFCO lower mount in the control arm .
Part number A550090108X. It does require welding but it can be done on the car if you dont want to pull the arm off . I made a simple drill guide with a 1/4" hole in the middle that bolts onto the OE bolt holes . Use a 3 3/8" bimetal hole saw at low speed and you will have a perfect hole to install the mount.
I actually just completed a set tonight for a Stocker. along with Global west bushings.
Name:	Camaro control arm.jpg
