Old 08-07-2021, 12:50 AM   #1
Bruce Fulper
Liked 54 Times in 33 Posts
Default Who's the local So. Cal. Jericho guru?
Seeking help on inspecting an early Jericho. Get it ready for racing.
Thanks
Bruce
909 844 ten eighty one
Bruce Fulper is offline   Reply With Quote
Old 08-08-2021, 08:17 PM   #2
Bruce Fulper
Default Re: Who's the local So. Cal. Jericho guru?
Doesn't anyone run a Jericho in Stock or S/S So. Cal.?
Old 08-09-2021, 07:25 AM   #3
Mike Jones
Liked 684 Times in 289 Posts
Bruce,
They are all switching to metric 200`s by Mark Yacavone. He posts on here and lives in AZ.
Old 08-09-2021, 02:55 PM   #4
SSDiv6
Liked 1,600 Times in 583 Posts
Because a lot of drag racers have switched to the G-Force transmission.
Old 08-09-2021, 03:24 PM   #5
Grey Ghost
Grey Ghost's Avatar
Liked 210 Times in 88 Posts
Does anyone in So Cal run a stick????
Phil Vos
Grey Ghost is offline   Reply With Quote
Old 08-09-2021, 06:47 PM   #6
Bruce Fulper
There are a few, and I will be one. Thanks for all of the direct positive responeses.
Old 08-09-2021, 07:21 PM   #7
Bruce, Don Keen probably knows a bit about that trans. I don't know if he does any side work.
Dennis Alvey knows them inside out, over here in Az. Again, I don't know if he would want to be involved..He stays pretty busy.
Looking forward to seeing this new piece. :-)
Old 08-10-2021, 05:21 AM   #8
james schaechter
Liked 1,438 Times in 301 Posts
The first thing you should do is look for the case number. It is stamped on most cases on the outside.
Call Jerico and find out what version it is. That will determine if it is a narrow gear or wide or what it is.
Take the covers off and count the teeth. Compare it to the gear ratio chart on Jerico’s web site
Look at general condition. Roll it over in each gear to feel for tight spots. Look at dog rings and sliders.
Beyond that it really needs disassembly to check it out.
If it is a narrow gear, it isn’t worth buying unless it has the ratios you need, is in good condition and in a low power light weight car.
You can’t get many parts for the narrow gear.
Older wide gear is possible to order some parts.
Buy some good quality snap rings pliers and read the manual that is also on line. Pretty easy to work on.
James Schaechter 3163 STK
Old 08-10-2021, 09:18 PM   #9
Bruce Fulper
I got this from the late Gene Stinnett, Garys dad, who I used to crew for. Even tho it came out of his 6 cylinder Nova he stressed it would handle 700 hp. I will get it out and do your inspection, plus I'll go to Jericho's site for gear width info. Thank you very much.
Old 08-12-2021, 09:28 AM   #10
Greg West
Liked 52 Times in 22 Posts
Roderick Racing had a Jerico recently listed for sale on Class Racer. He is from California. Maybe he is a "guru".
Greg West is offline   Reply With Quote
