Old 08-06-2021, 12:02 PM   #1
Nitroglenn
Liked 2 Times in 2 Posts
Default Light weight carpet
Where is a good place to buy light weight carpet ?
Nitroglenn is offline   Reply With Quote
Old 08-06-2021, 12:20 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Light weight carpet
You want to buy Ozite super flex carpet comes in a variety of colors weighs almost nothing---stuff looks like those green scotch scrubbing pads weighs about 18 ounces per yard comes in 80 inch wide by how ever long you want---usually sells for around $18-20 per yard ---thats for 80 x 36 18-20 ----look at ---YOUR AUTO TRIM STORE check out their website---you will need about 3-4 yards depending on what size car you have and how much you are covering---fasten it down with aerosol trim adhesive to hold it in place---if you want to do a removable trans tunnel you can form it real easy and take it to an upholstery shop have them sew a real nice edge on it so it doesn't come unraveled ----FED 387
Old 08-07-2021, 07:26 AM   #3
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
deleted
Andy Friar
Last edited by Andy Friar; 08-07-2021 at 07:31 AM. Reason: dumb suggestion on my part
Andy Friar is offline   Reply With Quote
Old 08-07-2021, 11:05 PM   #4
j gardiner
Liked 55 Times in 29 Posts
Ez flex on ebay
j gardiner is offline   Reply With Quote
Old 08-08-2021, 10:46 AM   #5
GTX5877
Liked 20 Times in 9 Posts
Home Depot. Around $18 a roll, approx 6' x 8', very light weight, easy to work with. Used 3M Super 27 or Super 77 for aerosol glue.
GTX5877 is offline   Reply With Quote
Old 08-12-2021, 06:50 PM   #6
rod
Liked 20 Times in 15 Posts
long years ago...the rule book just said 'floor covering'. I showed up with burlap [gunny sack] material. all nicely glued down. he didnt like it, but did have to pass it.
rod is offline   Reply With Quote
Old 08-13-2021, 11:02 AM   #7
chasracer
Just an FYI. A lot of pieces in a purpose built car like the trans tunnel or side door stuff can be covered in a peel and stick material. It has a carpeting look to it like the inside of a glove box, it's light as a piece of paper and it holds up really well. If it gets damaged, peel it off and replace. I see it in a lot of Comp cars.
chasracer is offline   Reply With Quote
Old 08-14-2021, 02:38 PM   #8
Bruce Fulper
Liked 54 Times in 33 Posts
Bought two rolls online. Got here yesterday. Super light!!
Bruce Fulper is offline   Reply With Quote
Old 08-15-2021, 07:16 AM   #9
richie 2
Liked 205 Times in 93 Posts
you just lay it right over & fit to frame rails etc?
