Old 08-15-2021, 12:51 PM   #11
Bernhard
Default Re: starting line gear ratio?
How does engine cubic inch and an engine's ability to RPM factor into the SLR?
Bernhard is offline   Reply With Quote
Old 08-15-2021, 11:23 PM   #12
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
I caught a little NHRA Stock qualifying highlights today from Topeka. I don't know much about this class really as far how elaborate the engines are allowed to be, or how much they have to weigh, but this car runs about like my n/a 23 degree sbc on 10" tire 69Nova.
What SLR do these class cars typically run? What transmission and how many rpm's do they typically cross? It was a current model Camaro, is it limited to an LS? I think the announcer said 409cid. Just curious, run pretty good seemed like.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 08-15-2021, 11:56 PM   #13
6130
Liked 117 Times in 50 Posts
An FS/C car is not a traditional Stock Eliminator race car, it's a factory race car with no VIN. The factory race cars come with Ford 9" rear ends and engine combinations that may not be available in regular production-based cars.
A better comparison with a traditional production-based Stock Eliminator race car, might be a '99-'02 LS 346 V8 Camaro A/SA car. The current national record in A/SA is 9.65 at 136.3 mph.
A car like that would have a stock throttle body, stock intake manifold, stock heads with an NHRA-legal valve job, stock bore (plus up to .040"), stock stroke, stock compression ratio pistons, stock valve lift, stock rocker arm ratio, and so on, with a "metric" TH200 3-speed automatic transmission with no trans brake, an 8" converter, and 9x30" tubeless radial slicks.
Old 08-16-2021, 12:40 AM   #14
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
here's a more detailed chart borrowed from Cale Aransons Black Magic clutch website ..........lots of useful information there.
http://www.blackmagicclutches.com/index.html
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 08-16-2021, 01:07 AM   #15
Mike Rietow
Very cool, thanks
I gotta find a way to watch/follow these cars more
Old 08-17-2021, 05:49 PM   #16
GTX JOHN
Liked 2,485 Times in 697 Posts
Rod: 350HP and 3600LB = 12.20 should be attainable.
Our Aspen Wagon NOP Stocker with 318 that put out actual
340 HP and weighed 3600 plus held the record @ 12.0 over
ten years ago.and ran 11.70 to 11.80 when needed.
It is an Auto so not comparable on ratios but shows what can be done on that HP/Weight.2.75 Low and 5:13 gear at Sea Level. 14.11 ratio and I think that stick would need a bunch more without a torque converter. 9.0x30 Radials (92.5 Cir.)
John Irving
741 Stock
741 Super Stock
Old 08-17-2021, 06:39 PM   #17
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
While HP and weight are very important you cannot leave out tire size when talking about SLR.
Stan
Old 08-24-2021, 12:20 AM   #18
Adger Smith
Liked 880 Times in 311 Posts
Stan,
I think I said" If traction is unlimited" or did I say available... ??
Adger Smith (Former SS)
Old 08-24-2021, 04:51 PM   #19
Stan Weiss
Stan Weiss's Avatar
Originally Posted by Adger Smith View Post
Stan,
Adger,
Size was to general a word to have used, I should have said Diameter.
Stan
Old 08-24-2021, 09:56 PM   #20
GUMP
Liked 2,354 Times in 554 Posts
You get my vote for "Clueless Post Of The Year".....
