Old 08-22-2021, 04:32 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Tuning LT1 Stocker Cam
Installed Stocker cam and runs great except at Idle.
Using the Pure Stocker a in file.
Runs rough at 800 rpm begins to shut down.
Figuring not getting a good vacuum with a much larger duration cam.
Will run at 1250 rpm but rough..
Runs through the upper rpm fine.
First step will raise Timing from 27 to 31 degrees see how that works.
Hoping that will work some.
But gut tells me other tables need to be tapped.
Dan
Old 08-23-2021, 04:01 AM   #2
GUMP
Liked 2,359 Times in 557 Posts
Default Re: Tuning LT1 Stocker Cam
Are you still running a factory ECU?
GUMP is online now   Reply With Quote
Old 08-24-2021, 03:09 AM   #3
Dan Fahey
Dan Fahey's Avatar
Yes…got some help from TC
D
