Old 08-22-2021, 02:45 PM   #11
Liked 11,000 Times in 2,263 Posts
Default Re: Micro Welding of bearing shell to rod housing bore
The welding on my 440 stocker engine is on the piston side of the rod. If the rod parting line would be 3 o’clock and 9 o’clock with 6 o’clock on the piston side. The most of the transfer of metal is between 3:30 and 4:30 on one side and between 8:30 and 7:30 on the other side, with very little if any at the 6:00 o’clock position. Rod and piston approx 1750 grams.
Old 08-22-2021, 03:09 PM   #12
SSDiv6
2.375 crank pin, 5W30 oil, close to .003 vertical bearing clearance, bore is round within .0002, stretch gage.
I'm not understanding how to check housing bore diameter with the bearing installed.
Thanks
The bearing has a thickness specification that can help you determine the amount of crush you are getting after you torque the rod. How many use cycles do you have on the bolts and what type of bolt are you using?
Old 08-22-2021, 03:40 PM   #13
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
OK, I have no personal experience with this problem. But have talked with someone who I believe had a similar problem. He modified his rod bearings to give a little more clearance in just that area and that seemed to fix his problem.
Stan
Old 08-22-2021, 05:10 PM   #14
dragracerray
dragracerray's Avatar
Liked 217 Times in 93 Posts
I have never had this problem. A long shot. Do you have your negative cable attached directly to the block? Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 08-22-2021, 07:25 PM   #15
Yes Ray the cable is connected to the block. I never considered an arcing or plating situation
Not sure on cycles on rods or bolts. Bolts are ARP 7/16 20NF 12 point. The big end of the rod stays rounder longer since we installed a clean neutral valve body in the trans. I use the brakes to stop the car without compression braking.
Old 08-23-2021, 01:25 AM   #16
Adger Smith
Liked 880 Times in 311 Posts
Larry,
The design of the bearing is important. The size of the rod bore determines crush. You may need a bearing with more ellipse or a slightly thicker oil for the .003 clearance.
It is a long read, but Mahle has a good read on bearings.
All bearings are not created equal!
https://www.speedperf6rmanc3.com/con...20Bearings.pdf
Adger Smith (Former SS)
Old 08-23-2021, 09:59 AM   #17
Thanks. I will read it
Old 08-23-2021, 12:04 PM   #18
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Which Manley rod and which arp bolt ?
Old 08-23-2021, 06:53 PM   #19
Glenn I cant find the info on bolts or rods. Bolt stretch is .0055.
I need to finish my engine to race BG this weekend so my response time will be long until we are at BG.
Thanks everyone for the help and input.
Old 08-24-2021, 12:50 AM   #20
CMcAllister
Liked 929 Times in 263 Posts
Strange.
So there is no indication of an oiling problem? i.e. crank to bearing face contact/damage?
Or bearing shell being hammered (detonation)?
Any indication of the caps moving on the rod (fretting on the cap/rod contact surface?
Fretting/welding indicates parts are moving under load. Initial thought would be to tighten (decrease) the bore size to the minimum to increase the crush.
All I got. Will be watching for responses.
