Old 08-28-2021, 06:31 PM   #11
MoJo Risen
Liked 143 Times in 52 Posts
Default Re: Spark Plug Heat ranges, what gains have you made?
Originally Posted by Terry Cain View Post
NHRA DOES check wrist pin location. Ask David Walther or Tom West. 1972 winners of div race at Muncie, IN until getting tossed for have stocker pistons in backwards. It's all been tried. Nothing new.
Thank you for some clarity.
Why isn't the stock offset listest in accepted pistion?
MoJo Risen is offline   Reply With Quote
Old 08-28-2021, 06:36 PM   #12
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Probably because it might not be a checking point now. Not sure. Need to ask Tech. Back in 1972 you couldn't run replacment pistons. Had to run OEM.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 08-28-2021, 08:14 PM   #13
MoJo Risen
Why isn't the stock offset listed in accepted pistons?
Old 08-31-2021, 12:50 PM   #14
GTX JOHN
Pin offset is no longer an issue that Tech is concerned.
John Irving
741 Stock
741 Super Stock
Old 08-31-2021, 01:37 PM   #15
CMcAllister
Liked 920 Times in 259 Posts
It ain't 1972 anymore.
Old 08-31-2021, 04:37 PM   #16
Rob Petrie E395
Liked 216 Times in 77 Posts
David Frieburger (might be spelled wrong) from Hot Rod magazine, engine masters, road kill ect ect. Just posted within the last couple of days that they tried the reverse piston trick on a 360. They saw no changes on the Dyno.
Old 09-01-2021, 07:49 AM   #17
Terry Cain
Terry Cain's Avatar
Yep. Back then they HAD TECH.
Terry Cain ???? STK
Old 09-01-2021, 01:14 PM   #18
Ralph A Powell
Liked 225 Times in 136 Posts
I now for a fact on the Boss 302 it was worth 10 hp as I was at Dyno the night we run it.
Old 09-01-2021, 01:39 PM   #19
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Ralph,
Do you happen to know how much offset that piston has?
Bore = 4.0 Stroke = 3.0 Rod Length = 5.155
Wrist Pin Offset = 0.06
Actual Piston Stroke 3.00022203042
Cylinder Volume 37.701902 CI 617.823481 cc
Engine Size 301.615216 CI 4942.587850 cc
Crank Angle Piston TDC -0.51657300450 Piston BDC 179.05939775907
Stan
Old 09-01-2021, 01:41 PM   #20
MoJo Risen
Thats approximately 2.5% gain?
There is more potential HP in a corrected Piston pin offset.
I'm glad we all know now that NHRA DOES NOT TECH THIS FEATURE.
