Old 09-20-2021, 01:37 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Power Brakes and Vacuum
Noticed that changing to the Stocker Cam from Pure Stocker.
Ran into two issues
Cannot hold the Converter as much on Launch.
Use to hold as much as 3200rpm.
Now barely launch above 2500rpm
The Line Lock will not hold the car during Burn Out.
Have to power brake to get the tires spinning.
Shut down after a run is no problem.
Is there a good solution to get more Vacuum Boost for the Power Brakes?
Old 09-20-2021, 04:46 PM   #2
Terry Witzel
Terry Witzel's Avatar
Liked 50 Times in 28 Posts
Default Re: Power Brakes and Vacuum
Ran into two issues
Dan, years ago I used to run one of these, the price has really gone up.
https://www.summitracing.com/parts/c...+5ba2536e62314
Old 09-20-2021, 05:12 PM   #3
Jim Whitehead
Liked 150 Times in 41 Posts
Electric vacuum booster.
Jim Whitehead is offline   Reply With Quote
Old 09-20-2021, 06:24 PM   #4
Bob F
Liked 16 Times in 11 Posts
I’ve built vac canisters using 4” pvc tubing as reservoirs and they worked well on the street.
Bob F is offline   Reply With Quote
Old 09-20-2021, 06:43 PM   #5
Tex013
Liked 44 Times in 26 Posts
a vacuum pump is needed .
You can use the one out of a G8 Pontiac / Aust Holden
This : https://www.hella.co.nz/en/products/...pump-up28.html
or this : https://www.amazon.com/ACDelco-20804...ic+vacuum+pump
You can run full time , race only or switched
Like this : https://www.amazon.com/Superior-Univ...HSQKDHY2J27ZZ3
Tex
Tex013 is offline   Reply With Quote
Old 09-20-2021, 11:10 PM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Remove the booster and switch to a manual master cylinder and save all the weight .
ss3011 is online now   Reply With Quote
Old 09-21-2021, 10:22 AM   #7
garyc
Liked 51 Times in 30 Posts
jegs has a electric pump for brake boosters
garyc is offline   Reply With Quote
Old 09-21-2021, 10:22 PM   #8
SSDiv6
Like SS3011 said, get rid of the booster and install the 9C1 police car brake master cylinder with the 1-1/4" bore size.
RockAuto has brand new master cylinders with the reservoir, Wagner P/N MC131285 on sale for $34.00.
Also, search for a 1993 to 1996, 9C1 police car brake pedal assembly with the pushrod. They have a different brake pedal pushrod lever point.
Old 09-22-2021, 04:51 PM   #9
Dan Fahey
Dan Fahey's Avatar
Does that work well with Disk Brakes?
Got this one in today
GM Genuine Parts 20804130 Power Brake Booster Auxiliary Pump Assembly
Have to figure how to mount it and get a Male Connector.
Dan
Old 09-22-2021, 06:15 PM   #10
Tex013
here is another pressure switch
https://www.amazon.com/dp/B078T5NL4S/ref
This is similar/same as what they use in the COMP and similar vacuum pumps If you want switched pump operation .
Tex
