Old 09-24-2021, 10:22 AM   #1
Shadylane
Shadylane's Avatar
Liked 173 Times in 52 Posts
Default Trailer A/C recommendation
I have a 2006 Pace American 26ft that the A/C works intermittently. It's an older Carrier IV. I've replaced a few parts that I thought might cure it but since they no longer make these units or replacement parts I've decided it's time for a new unit.
looking for recommendations on brands, would prefer a soft start as it has to run off of a Yamaha 3000 inverter generator.
Kelly Lane
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
Old 09-25-2021, 08:54 AM   #2
steven reynolds
Liked 13 Times in 11 Posts
Default Re: Trailer A/C recommendation
I've had good luck with Coleman 13,500 btu air conditioner with heat strip, runs good on the 3000 watt generator , this is on a 28ft trailer
Steve
steven reynolds is offline   Reply With Quote
Old 09-27-2021, 07:45 PM   #3
Shadylane
Shadylane's Avatar
Steve
Thanks, I’ll check it out.
Kelly Lane Stk4991
Old 09-28-2021, 10:00 AM   #4
1matcoman
1matcoman's Avatar
Liked 361 Times in 140 Posts
Kelly, there's no question that the 13.5 Coleman unit is the way to go. Just be aware that when running it in super hot weather, it'll pull close to 2K watts and not leave you with much more power for anything else. But, like most racers, you'll probably only use the AC unit and a battery charger for your hot rod, so you should be good to go with your generator.
Search this Thread:
Advanced Search
